Any full length carbon fibre radiator guides (as shown in pic) for an R32 GTR?
Not in stock just at the moment but we are working on some from Japan.
We will keep this thread updated :cool:
Cheers.
Steve
  • Replies 67
any stuff for 350z and c33laurel
We are expecting to have Z33 bonnets and bootlids available very soon, however we don't have anything available for C33 im afraid.
Cheers,
Steve
  • 2 months later...
hay buddy
i just noticed that the r34 carbon bootlids have a hole in them is that for the key hole. can u get them with out that as i have removed my bootlock and intend on staying that way when i get a carbon bootlid
thanks
julz
hay buddy
thanks
julz
Hi Julz,
Only the style shown is available unfortuantely.
Regards,
Steve
  • 3 weeks later...
hey guys,
have you made any progress on the 32gtr replacement parts list... i am going to buy the rear n1 lip, n1 bonnet lip and n1 vents... but i just thought i would ask if u have anything in stock or on its way??
cheers :blink:
  • 1 month later...
Do the carbon r33 bootlids sit flush or does it dip down like the stock boot lid?
And are they adr approved?
Hi mate, thanks for your enquiry.
The R33 Karbonetic Carbon Trunk sits flush, and we have not had them ADR tested.
Regards,
Steve
Is it possible to get a replacement front lip for a R32 GTR? My front bar is fine, but the lip has seen better days. I just want a stock looking one in carbon if possible...
Hi Steven,
I may be able to source one of these for you, please give me a call in the store to discuss.
(02) 9545 0532.
Regards,
Steve
Do the R33 GTR bootlid have holes in it as shown in the pic? I would like it without holes as I want to put an aftermarket wing on it.
Himmy
The R33 Karbonetic trunk has indents where the holes would normally go, however they are not drilled out, so you have the option of leaving it that way and fitting an aftermarket wing, or drilling out the hole to fit an original.
Regards,
Steve
  • 4 weeks later...
We are just in the process of unloading a massive container choc full of Carbon goodness!
Carbon Doors for S13, S15 and R34 GTT/GTR, BNR34 Carbon Front Fenders, Carbon Bootlids, Bonnets and much more! Stay tuned to our website for details!
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
