You can also look into putting steel wheels into your turbos, if its a tight budget and only looking at slight performance. I'm running 17psi on my ones and 287rwkw with supporting mods and it cost me $1100 with all the labour done myself, I bought the turbo cores of a member here with the wheels already balanced and ready to go and just added my exhaust housing and compressor housing of the old turbos. Not that hard if you have basic mechanical knowledge, I had no issues doing all this myself and saved alot on labour.
But if budget allows, do what R31Nismoid recommended earlier Garrett -7, much better than my option and can make much more power as well as less work involved.
Cheers
Aren't the -9's the way to go now instead of -7's? (or are they more expensive?)
Well Nismoids above post has thrown me as for the past few months I have noticed he is a pro -9 man :P
Edited by gtr fan
i can vouch for garretts being the best choice for a street replacement on a budget.
i would say go the -7's or -9's
i've got -5's which are a little bit of overkill, i only got them because they were the ones that came available the soonest when my stockers blew the rear wheel off.
the -7's or -9's would be better for response and still have plenty of power!
i hope your mates car will be fine after he gets the turbo's replaced and doesnt have my luck and have the motor blow a week and a half after the new turbos are installed.
His post says slight improvement over factory, -7's are the closest.
-9's are 330rwkw, which IMO i wouldn't be taking a R32 motor to that level given their age/conditoon now.
So 280rwkw or so on -7's would be reasonable and about 30-40rwkw more than factory turbo's.
If he wanted a bit more performance, with a planned rebuild, then -9's for sure.
Say you were running 300kw, would the -9s produce that with a slightly lower temperature (due to the better compressor efficiency) than the -7s? Or are they only better when you're running them right at the peak?
Not 100% sure but it's not going to be a 30 degree difference or anything major i would imagine.
Probably a difference, however majorly signifigant? Probably not.
300rwkw i would still pick -9's though. 280rwkw would be the aim for -7's.
just a slightly off topic question....why are the power out puts between a -7 and a -9 so different, looking at the spec sheets they are so close to the same it isnt funny (-9 slightly smaller in the compressor and slightly larger in the turbine but we are talking 0.0Xmm difference)
Rebuild it with steel internals or go for R34 GTR N1 turbo's.
Or any aftermarket that is listed in thread.
what is the benefit of N1 turbos , everybody says there great , what would a pair set me back!
They came from factory on the R34 GTR V-Spec II N1, R34 GTR V-Spec II Nur and R34 GTR M-Spec Nur.
R34 GTR N1 turbos came from factory with steel internals and they ran 1.2 bar boost stock.
So they are very strong and responsive.
I had driven a R34 GTR V-Spec II Nur with 306 rw kW's still retaining the N1 turbos.
Was excellent.
Try the for sale section and from memory about $1450 + a pair.
- http://www.skylinesaustralia.com/forums/Wr...mp;hl=n1+turbos <--- He's selling them for $1450 a pair.
Should be straight bolt on fit too.
Was excellent.
After reading a few topics and the GCG website the gt2860r-7 are equalent or closest to n1 turbos that came in the cars that you mentioned.
My understanding is that the gt2860r-9 are equalent or closest to HKS GTSS.
The physical dimensions of the wheels are one of MANY variables. The -9's have newer more modern wheels which flow more and more efficiently without needing to be bigger or lighter.
To the previous posts about the -7 turbos, I'll say it again, -9's AREN'T any laggier than -7's so there is NO advantage of -7's! If u only want to make a certain amount of power, just run -9's on low boost!
Damn that is bad luck
Im guessing the ceramic turbos did the damage initially.
I was thinking the way to go is gt2860r-7
Are bigger turbs generally more laggy.
Everyones advice has been extremely helpful .
why not -9's? Newer more modern turbo. Same response, more efficient, more power, same price. I dunno why they don't discontinue -7's and put an end to all this confusion.
Yeah, I think your right, by looking at my Turbo Chart, the specs seem the same.
And yes the -9's = HKS GT-SS (well, very close)
    • You're not the first person that's said that about this car lol. A Touring wagon GT in Spark yellow mica would be the dog's danglies 😆 I will keep an eye out for a future purchase for sure. The seats are almost like the OEM Recaros... electric adjustment for fore/aft and tilt movements except reclining.
    • Yes!! I love these! It's a shame its not the wagon though!   Thank everything that's holy that it doesn't have the interior of the Aussie delivered ones. Those seats are so much nicer.
    • I'm both sorry and thankful that you do that.
    • 2001 BE5D Subaru Legacy B4 RSK (3rd gen) EJ208 (pink injector) Twin Turbo 280PS 5-speed manual Full time 4WD "RSK" grade which means all of the above LQC option which means stock rear spoiler  I got it primarily to export to someone outside Japan who was interested. These BE5 Legacy B4 RSKs are going through a bit of a resurgence right know in Japan as they are one of the few cars from the "turbo, manual, RWD/4WD, 280hp gentleman's agreement era" cars that don't require stupid money to purchase. Which for some people might be a good opportunity to get as a base for restoration. If I can't find anyone to purchase it I will certainly be doing that myself over the long term. Why? Because it's properly fast in stock form, handles well enough for a GT sedan, there's still enough aftermarket and (if you can wait a while) genuine part support to make it a restoration candidate (<-- that will only get worse over time so it's a case of do it now or choose get a BL5 4th Gen). Mechanically it's fine, has only 89,200kms on the odometer. The problem with this car is that the body and exterior trims are weathered from at least the last 10 years being parked outdoors. I'm the 3rd owner, the first owner was the one that had it for 14 years and barely drove it, had a low-speed front impact (which didn't damage anything behind the radiator support) and got it fixed and sold it. The 2nd owner put most of the kms on it and parked it outside for the last 10 years, hence the door rubbers have seen better days but if you overlook those cosmetic details, it presents pretty nicely. There is some minor rust on the LH rear wheel arch which I'll have looked at too at some stage.  Also as you'd expect from a car this age, the clear top coat is gone, leaving a satin finish on the roof.  Mechanically it's fine (as you would expect from a car with less than 100K kms) but the steering does feel slightly vague around the centre position at higher speeds. So first on the list is to get the steering rack bushes looked at. There's also the Lock button on the remote which doesn't work, but the Open button does.... it means that the anti-theft system thinks it's always open? It seems like if you open the car and don't start the engine within 3 mins or so the anti-theft kicks in again without any beeps or signals. So if you got to start it after that, it won't. You have to push the open button again. That's how I understand it anyway. Just a small irritation but not a big problem to sort out. There's only one mod, the Wangan SPL muffler. Just a tad louder than stock. It's a really good mod for those who don't want to wake the neighbours but still want to hear a more prominent unequal length header EJ20 sound. Anyway I hope to get all those things done eventually, that is unless someone wanted to import it to their country from Japan (where I live). I'm open for negotiations as I really would like a Skyline... but this will definitely suffice in the meantime 🙂 *Disclaimer: This is how I picked it up from the dealer, minus the stuff on the back seat. I haven't cleaned the engine bay or done a thorough exterior clean, aside from spray painting the wipers.
    • Wow, even with the Audi logo centre caps. I love OEM wheel mismatches.
