What do you guys reckon of Link computers for R32s?
I know quite a few New Zealand guys use them and seem to like them.
Which would be better between a Link computer and a remap for an R32 RB20DET with FMIC, full exhaust, T04E, external gate, bigger injectors etc etc
Cheers
https://www.sau.com.au/forums/topic/30683-r32-link-or-remap/
Hi JiMiH, my choice would be to remap in real time the standard R32GTST ECU, if you have finished your mods. If you still have things to upgrade, then a Power FC would be a better choice as the extra cost would be covered by the saved chip burning.
Hope that helps
https://www.sau.com.au/forums/topic/30683-r32-link-or-remap/#findComment-622820
i went to get info on the new wolf 3D for my rb20det and the bloke said that there was nothing better than the link ECU for a rb20det and then he told me it would be $2300 fitted and tuned so i tuned out, am now looking to remap the factory ecu to get my end results for a thrid the cost!
https://www.sau.com.au/forums/topic/30683-r32-link-or-remap/#findComment-623975
How does the Wolf compare to remapping the stock ECU then?
I mean apart from the "wanky" features that you can get such as rotational idle, are there benefits of a Wolf3D above a remapped ECU?
I haven't finished my mods yet, but I think once you have a remapped ECU you only pay for dyno time later to retune it?
https://www.sau.com.au/forums/topic/30683-r32-link-or-remap/#findComment-626337
James,
I took the remap route and all is sweet at the moment. The place that did my tuning, as you know, are able to do pretty much anything with the ecu, except for the features as you mentioned. They can also do a few other really cool things with the ecu as well. Bit hard to explain on here but they can put on "Valet" mode etc. Stops dickheads thrashing your car basically.
A whole lot cheaper than a Link I'd imagine.
https://www.sau.com.au/forums/topic/30683-r32-link-or-remap/#findComment-627774
I know enough about the Link not to suggest anyone uses them:p
JiMiH, The wolf will provide so many more features over the remap, without getting into the wanky stuff like anit-lag rotational idle etc. Pop down to see Steve at SST he'll be more than happy to run through some of the feature and demo the software to you:D
https://www.sau.com.au/forums/topic/30683-r32-link-or-remap/#findComment-627808
Yeah I spoke to Steve at the drags the other night and told him I'd pop in one Saturday morning to check it out.
Dan, I'll have to have a chat with you soon mate and you can tell me bout your remap :( Not to mention take me for a drive :(
https://www.sau.com.au/forums/topic/30683-r32-link-or-remap/#findComment-627817
Traction control is wanky stuff:p The traction control works via hall-effect sensors, and sends a signal to the engine to drop the power, rather than a second butterfly infront of the plenum like the factory fitment traction controls use. Not much good on turbo engines as it lets the turbo fall off boost.
https://www.sau.com.au/forums/topic/30683-r32-link-or-remap/#findComment-629393
save a dozen maps on your pc
give the bagging a rest, RIPS times are a recommendation for the stuff and ive seen 100's of cars run link with awesome results and no problems. objective debate might be better to base a decision on but is sometimes a little difficult for some
pm me jimih i can help you out with heaps of cars running it but a remap would be cheaper and just as effective as an aftermarket ecu
https://www.sau.com.au/forums/topic/30683-r32-link-or-remap/#findComment-630526
    • Yes the gear for the R33/34 is different, it is red and has a different number of teeth. My part didn't come with that gear though, so I don't know how many teeth are on the red one. You'd have to reuse the 260RS/R33 gear, as long as it's not destroyed.   Haha, as unfortunate as that might be it was working fine for about the first 1500km I've had the car for now.
    • Update all   thanks to the workshop manual, it lead me back to checking fuses as mentioned central locking and door open lights worked when acc was switched on. diagram attached shows two points of power 1. ACC and 2.  Batt with the later being fused (#28) I did check the fuses using a multimeter but I must have stuffed that up also. Went back and checked the batt fuse in interior fuse box and you wouldn’t believe it… a blown fuse. replaced fuse and everything is now working as it should including the climate control   thank you all with your positive insight and knowledge.
    • Where is the warning "That this thread is super old"   I just went into a 5 year old thread, went to do a reply, and couldn't see anywhere obvious a warning of it being super old
    • Duncan is correct. Pitwork (and Toyota's own cheap brand "Drive Joy") were primarily created as brands to sell other manufacturers car parts. It would be weird if Nissan sold parts for Toyota vehicles with a Nissan logo on it, so they created Pitwork to sell parts for other brans Toyota, Honda etc. They are not the same as Nissan genuine parts, although they *do* meet Nissan's standards for replacement parts. They aren't supposed to be a substitute for genuine parts, but a cheaper alternative that is better than Ebay fake parts from you-know-where.
    • Thanks GTSBoy, much easier to work with it now it's free!
