thank you savman, im going to go with the 14 then, i really like the rear to have a solid lock, dont mind it on the street.
nzm - yes they are alloy. if you have gtst and want to upgrade to alloy knuckles you need z32, not gtr
  • Replies 136
i have the 2007 nismo catalog, but there are (4) kits available? take a look, do you know the differences?
could you please you ask your mate if he got the 8kg or 12kg? and serrated disc or smooth disc?
the one you want is either 3843S-RS520 (45ft/lb) or 3843S-RS521 (75ft/lb). for your car I'd go with the RS521 kit.
the one you want is either 3843S-RS520 (45ft/lb) or 3843S-RS521 (75ft/lb). for your car I'd got with the RS521 kit.
yes, thank you beer baron!! that is exactly what i was thinking, sent an email to a nissan buddy of mine to try and get that for me. What do you ascertain to be th difference between serrated disc and smooth disc? i suppose the serratted disc would run slightly cooler due to having more gear oil between the plates
no worries. to be honest I've never used the RS650 or RS651 kits and in fact I think only the RS651 is still available. I've only used the RS520/521 kits and used a fair few and they are great. Definitely without the serrations it will alter the oil flow through the plates and I'd say the ones with serrations will lock up a lot harder even though you end up with less surface area as they are able to dissipate the oil. you can see the patterns on the 520/521 kits alternate between plates with some running concentricly around the disk face and the next ones running out from the centre. it must make them grip better.
I'd say you'll be happy with the RS521 kit and they are a great bang for buck mod. it's the same kit for 32/33 and 34 GTR as long as they are not the active diff models.
that is the best info ive received in years THANK YOU!!!
Im really excited to use this kit in my R32/R33 rear diff, but had no idea it would fit the R34 diff also! Would the vspec be the active diff model you are referring to? We have an R34 here which i would love to do this to, I had no idea this kit would work there also. Thanks for the info
btw some great info here on link lengths: http://www.nismo.co.jp/en/products/competi...suspension.html
Edited by Full-Race Geoff
yep, Vspec and Vspec II have the active diff. only the non-vspec R34 GTR diff is suitable for this kit. and just confirming of course it's not suitable for any GTST diffs, they are all viscous or some models have the active diff same as the Vspec GTRs do. 33 GTR Vspec is active diff too. basically any of the plain jane mechanical 2 way GTR diffs are suitable, 32/33/34. anything else is not.
yeah the pro circuit link nismo kits are quite good (albeit a bit mild). that's the same thing we do to get circuit spec alignment. shorten the castor rod (obviously for circuit we usually got a bit further than those arms), lengthen the lower control arm a little which helps with camber, shorten the upper arms for the same reason. they also provide that inner upper control arm mount which moves the angle of the upper control arm so it's not getting twisted so much as it does when you are running more castor. from memory it also mounts a little higher too to help correct geometry for lowered cars. unfortunately you can't get that re-designed mount on it's own you have to buy the kit with the mount, castor rod and lower control arm which sucks if you already have adjustable castor rods and lower arms.
oh, and you're welcome! (^_^) always happy to help a fellow traveller. it's what we do here. it's what this forum is for. :ninja: we share a lot of knowledge and ideas here and you've certainly shared plenty with the development of your own car.
  • 3 weeks later...
  • 4 weeks later...
The new issue of modified magazine is on news stands, check it out!!
We got 2nd place in AWD class. :whoops:
Full-Race has recently received a lot of PMs and emails now that the new issue of the Tuner shootout is on newstands. The updated R14 portion of the Full-Race.com site is coming next week, but to answer the basic questions, ill copy/paste the beginning text for you:
Full-Race.com -- R14 DIY HOW-TO info
this portion of the Full-Race.com website breaks down the R14 conversion in detail. Pictures and information help to make it clear how to do this AWD RB26 swap. If you've done a few different motor swaps, installed some turbokits, know how to use a hand-drill + welder (220 Volt Mig welder recommended), and are committed/prepared to take on a big project you can tackle this install. If you dont know how to do swaps or install aftermarket turbokits, do not start this conversion until you have more experience or better understand the process.
A) Required BIG parts:
-(95-98) S14 Chassis, S15 will work too. S13 will NOT work for this swap!! <
-R32 GTR front clip w/ complete front suspension and complete rear subframe <easy to find at any big JDM importers/yards>
-Full-Race R14 DIY kit
^^^If you can acquire all of the above items^^^ all the big purchases are out of the way.
B) Full-Race R14 kit consists of these parts required to do the swap:
R14 Frame Rails (Left and Right side)
R14 billet frame blocks
Subframe Bolts/washers
LHD RB26 steering rack
Transmission Mount
Frame side Transmission Mount-plate
Front Upper-Control-Arm Structure (Upper Shock mounts)
Lower Shock mounts
1-piece Driveshaft (Aluminum or Steel)
1/2" Eye-to-Eye Coilovers - Moton or Koni (Circletrack or Road Race style heim-mounted)
Here is how it all works, and enough instructions to get you going:
First, start by getting the R32 GTR clip fully disassembled. We will be using almost every major component from this clip. Keep all the suspension control arms, brakes, hubs and bolts sorted, with their respective hardware. The engine and transmission should be inspected and it is recommended to refresh it - new timing belt, clutch, oil pump, etc. At this point, the subframe should be unbolted from the motor mounts and then cleaned/prepped for the swap....
to be continued. Thanks for the interest in the R14 conversions!
  • 1 year later...
  • 7 months later...
would really love to hear how this is going now. inspiring build, I want more updates, NOW =D
Ive been busting my arse to get the car ready for the race this year, March 30/31. One of the biggest changes for me was the addition of the ETS-pro center diff controller (torque split controller). I began my installation last night, hope to have the install completed later today
once my new PS pump arrives i can test it out!
pulling hours to get r14.1 in the modified tuner shootout march 30th. long story short, I was busting my ass to get my daily driver evo project ready for the modified tuner shootout. I hoped to run my evo for this as its debut race. unfortunately there was a mixup and modified mag put me down to enter the R14 (they didnt know i was building an evo) and said there are too many evo entries... if I wanted to be in the race i have to race in my nissan. So the heat is on, im getting the R14.1 ready again. There is a chance an evo will drop out, and in that case ill try to race 2 cars
here is the update:
-engine/fuel system/cooling system all remain untouched. nothing related to the engine had any damage from the fire. same intake manifold/ itb's and fuel system. i would like a better ECU, but oh well
-turbo manifold changed along with smaller MVS wastegates in a compact location - this allows for recircing the wastegates for emissions compliance (similar to our sr20 twinscroll kits) here is a pic of the work in progress:
-Turbo changes: installing an EFR 8374 turbo
-brakes are the same brembo G35/350Z brembo tracks ive had forever with raybestos race pads. I may use project Mu club racer pads instead (those are on my evo right now and amazing). Not sure if i will have an ebrake or not?
-suspension remains unchanged, moton double adjustables. found a bind at the front tension rod... i stole an idea from midori and it backfired. went back to OEM, no problems. May go softer on the spring rate to accomodate having to use a street tire instead of slicks
-ditched stock p/s pump, went to 1992 toyota MR2 electric powersteering pump. currently it is located in the trunk. the fire happened from my aluminum exhaust bursting and burning up a p/s hose. I ran a complicated AWD hydraulic circuit to control the torque split and p/s rack all ran through the p/s pump, so when the hose burst a large volume of ATF sprayed all over the bottom of the chassis and the exhaust lit it up. By eliminating the entire ATF system and proximity of p/s pump from the turbo and exhaust i have removed that possibility for fire. these are the changes i've made:
-installed OE nissan atessa system with new ETS-pro g-sensor software. this is the same thing as DCCD-pro that GST uses to run STI driveline in their gc chassis. info here: http://www.gtr.co.uk/forum/1486450-post53.html
-ive rerouted all the power steering and torque split lines so they are with the fuel lines - far away from the exhaust! (no more fire).
-kognition rear wing, braced to chassis? not sure if i will leave the wing off becuase this is a low speed track now (firebird west) and ill save the wing for R14.2? decisions
-removed sunroof, replaced with kognition carbon sunroof plug
-i installed a new OE fuel tank and replaced fuel lines just to be safe
-removed stereo
-removed heavy ass front splitter mount, will attach splitter to small lightweight aluminum frame or not at all (havent decided yet)
IF TIME PERMITS:
-carbonetic triple carbon clutch and rear LSD (already have a quaife front diff)
-R34 GTR 6 speed transmission and driveshaft
my car doesnt have only 2 small full-race stickers on it, and will stay that way for the comp.
weve got work to do!
as for the mounting of the splitter I have about 0.000001% percent of your Fab knowledge BUT..what I used for my main mounting of my bar/splitter was some 200lb fishing leader (I have it around as we are big on game fishing) and mounted it to the rad suppot panel with some nice stainless turnbuckles. tensioned them right up and its really sturdy. shouldnt be too rigid if it bottoms out (it shouldn't) I just mounted some nice eyelets to the splitter and made up the cables and yeah. 500 grams of bracing and with four of them its mighty strong. anyways I'm keen to see what you come up with!
cheers, Jack
    • Wow, thanks for your help guys 🙏. I really appreciate it. Thanks @Rezz, if i fail finding any new or used, full or partial set of original Stage carpets i will come back to you for sure 😉 Explenation is right there, i just missed it 🤦‍♂️. Thanks for pointing out. @soviet_merlin in the meantime, I received a reply from nengun, and i quote: "Thanks for your message and interest in Nengun. KG4900 is for the full set of floor mats, while KG4911 is only the Driver's Floor Mat. FR, RH means Front Right Hand Side. All the Full Set options are now discontinued. However, the Driver's Floor Mat options are still available according to the latest information available to us. We do not know what the differences would be, but if you only want the one mat, we can certainly see what we can find out for you". Interesting. It seems they still have some "new old stock" that Duncan mentioned 🤔. I wonder if they can provide any photos......And i also just realized that amayama have G4900 sets. I'm tempted too.
    • Any update on this one? did you manage to get it fixed?    i'm having the same issue with my r34 and i believe its to do with the smart entry (keyless) control module but cant be sure without forking out to get a replacement
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if something was binding the shaft from rotating properly. I got absolutely no voltage reading out of the sensor no matter how fast I turned the shaft. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if shttps://imgur.com/6TQCG3xomething was binding the shaft from rotating properly. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • perhaps i should have mentioned, I plugged the unit in before i handed over to the electronics repair shop to see what damaged had been caused and the unit worked (ac controls, rear demister etc) bar the lights behind the lcd. i would assume that the diode was only to control lighting and didnt harm anything else i got the unit back from the electronics repair shop and all is well (to a point). The lights are back on and ac controls are working. im still paranoid as i beleive the repairer just put in any zener diode he could find and admitted asking chatgpt if its compatible   i do however have another issue... sometimes when i turn the ignition on, the climate control unit now goes through a diagnostics procedure which normally occurs when you disconnect and reconnect but this may be due to the below   to top everything off, and feel free to shoot me as im just about to do it myself anyway, while i was checking the newly repaired board by plugging in the climate control unit bare without the housing, i believe i may have shorted it on the headunit surround. Climate control unit still works but now the keyless entry doesnt work along with the dome light not turning on when you open the door. to add to this tricky situation, when you start the car and remove the key ( i have a turbo timer so car remains on) the keyless entry works. the dome light also works when you switch to the on position. fuses were checked and all ok ive deduced that the short somehow has messed with the smart entry control module as that is what controls the keyless entry and dome light on door opening   you guys wouldnt happen to have any experience with that topic lmao... im only laughing as its all i can do right now my self diagnosed adhd always gets me in a situation as i have no patience and want to get everything done in shortest amount of time as possible often ignoring crucial steps such as disconnecting battery when stuffing around with electronics or even placing a simple rag over the metallic headunit surround when placing a live pcb board on top of it   FML
