Hey guys
I need to remove my fuel vapor canister as it is in the way of my intercooling pipes, i've looked all over google on "how to's" but cannot find anything worth reading. so i thought this would be my best bet
I've followed the 3 hoses around, ones a vacuum hose, and the other two dissapear underneath the car somewhere. When i remove this, can i just plug the vacuum line? and what should i do with the other two hoses?
All help is greatly appreciated, thanks guys
https://www.sau.com.au/forums/topic/306968-removing-the-fuel-vapor-canister/
IIRC One hose is the vacuum signal to operate the valve, one is plumbed into the intake somewhere and the other will go to the petrol tank.
You can get hit pretty hard for disconnecting emissions equipment, so if its a street car much better to just move it as suggested.
From the carbon canister its a rubber hose that goes to a solid hard line. This solid hard line goes along the firewall behind the engine, then down the drivers side along the solid fuel lines. Right at the back of the car in front of the RHS wheel you will see these lines going back up towards the petrol tank. The solid line will go back to a rubber line. Disconnect it here and just vent it to atmosphere or as i said, a one way check valve would be ideal.
You would have the check valve so if fuel flowed out, it would close up.
The check valve won't close up from air movement, too slow, not enough force. If it were a change of say the tank being pressurised 50PSi, then yeah, it'd close, but not from heat expansioin.
    • Just a thought, was that car and auto at any point of its life? If so, maybe whoever bridged the inhibitor switch/circuit did a not so good job.
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
