I have googled this many times and read all the power fc instructions etc and guides,
But i have just installed my Power fc and the car wont start, its a rb25det r33 s2
Its the right model and comes up as rb25det on the hand controller, ive turned the boost controller kit off, and i have reset it many times and the car just wont start,
The senor check shows no warnings or flashing lights so everythings ok there,
Could it be the earthing? or would that not make the hand controller work? or the powering etc? how do you check?
Iv run out of ideas...im worried iv brought a 2nd hand lemon and dont want to take it to a shop quite yet unless its my only option now?
im worried its faulty! :blink:
thankyou,, your help is really appreciated!
https://www.sau.com.au/forums/topic/308067-power-fc-help/
Is there any power to the car at all??
Headlights, horn etc.i have an r34 GTT and it used to have no power whatsoever on some occasions. headlight, interior lights, couldnt even use the central locking, like there was no battery.
Took me a while to figure out what was going on, as i had put neons underneath and only happened after they had been installed. i rang my mate who helped with the installation and he said disconect them. so i did and it fixed the problem. But what it was is when i touched the battery terminal it earthed through me i guess and then started no probs. So u may have a faulty earth. lift the bonnet and touch both terminals of your battery and see if that helps.
https://www.sau.com.au/forums/topic/308067-power-fc-help/#findComment-5085916
does it turn over? maybe you bought a series 1 power fc. series 1 rb25's have ignitor on the coil pack cover. series 2 have individual ignitors built in to the coil packs themselves
How do i tell if its a series 1 or 2 ecu?
It turns over but just doesnt fire up
https://www.sau.com.au/forums/topic/308067-power-fc-help/#findComment-5086005
check that when you titghened the centre bolt that the plug did no banana, sometimes only the centre get pulled down and the two outer edges dont seat fully. Firmly push each end it all the way. If not listen for the fuel pump prime whilst cranking. It is quite common for dead PFC's to light up but give no fuel pump prime signal.
https://www.sau.com.au/forums/topic/308067-power-fc-help/#findComment-5086043
theres no such thing as a s1 pfc. all 25 pfc's are the same and work on both s1 and s2
start with the basics, check for fuel and spark
https://www.sau.com.au/forums/topic/308067-power-fc-help/#findComment-5086175
read the PFC FAQ in my signature, it includes a section on car not starting
check the basics
i assume it works on the std ECU, does the car have any stange mods? any wierd boxes or wiring loom hacks etc?
ECT, SENSOR SW CHECK
what are the values of
AFM1
02-1
WTRT
TPS
NTR
please let us know
https://www.sau.com.au/forums/topic/308067-power-fc-help/#findComment-5086186
check the basics
AFM1
02-1
WTRT
TPS
NTR
please let us know
AF-1 is 0.22v
02-1 is 0.4v
WTRT is 3.48v
TPS is missing??? i dont see it on there...
NTR is on...got the black dot filled in
My bost is at 0.00v is that a problem?
Actually ill write them all up>>
AF-1: 0.22V
THRO: 0.45V
BOST: 0.00V
WTRT: 3.48V
02-1: 0.04V
EXTM: 5.00V
IGN: black dot on
STR: off
A/C: off
PWS: off
NTR: on
ECC: on
WRN: off
EXT: off
F/P: off
FP1: off but voltage goes on when i try start it
VTC: off
02H: off
ACR: off
Sorry i couldnt take a picture, hopefully this might help
Edited by R33 0wnerrr
https://www.sau.com.au/forums/topic/308067-power-fc-help/#findComment-5086547
ah yeah sorry its called THRO
they all seem normal
read the PFC FAQ, for some strange reason if a given fuse is missing (the FAQ has which one) the car wont start with the PFC, but will with the stock ECU
https://www.sau.com.au/forums/topic/308067-power-fc-help/#findComment-5086571
Ive been reading through your pfc faq but i cant seem to find out were it says which particular fuse in the faq like u said above, should i be looking for missing fuses in my fuse box in my dash, aswell as the ones in the boot and in the engine bay?
https://www.sau.com.au/forums/topic/308067-power-fc-help/#findComment-5087815
yeah its defintely in there
why it occurs, we dont know, but have seen it on a number of cars
stock ECU works fine
PFC doesn't start, check the fuse, it's missing, install fuse, car starts
im not even sure what fuse it's meant to be, ie what is the socket wired to ?
https://www.sau.com.au/forums/topic/308067-power-fc-help/#findComment-5088229
I checked the fuses...every single one...there all fine and i had those engine controll the "missing fuse" already in my fuse box and checked it and it wasnt blown or anything...checked the ones in the engine bay, and also the onese in the boot...there all fine... but there was one fuse i have missing the 2nd from top right hand corner called A/T 10amp one, but a fuse wont go into it because there is nothing hooked up to it.... so dont think thats to worry about?
Ive opened up the ecu aswell to check if its blown or anything...cant see anything...but the hand controller or anything wouldnt work would it if the ecu is stuffed would it?
car sounds so close to fireing up but just keeps turning over...any other ideas?
https://www.sau.com.au/forums/topic/308067-power-fc-help/#findComment-5088504
maybe the ecu is stuffed....i took the ecu out and the car dash lights and everything turns on and works, and the car even turns over all without an ecu plugged in....so it works the same as having no ecu when the power fc is plugged in except the hand controller works.... how do u tell if the ecu is stuffed?
https://www.sau.com.au/forums/topic/308067-power-fc-help/#findComment-5088740
plug the stock one in, if it starts the PFC is U/S.
Try initailizing the pfc aswell then try starting it before you do anything else, it may have a real weird map in it for big injectors and AFm etc..
https://www.sau.com.au/forums/topic/308067-power-fc-help/#findComment-5088938
Yea i already reset it to its default settings many times...not working....this is such a pain!
https://www.sau.com.au/forums/topic/308067-power-fc-help/#findComment-5089550
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
