I'm wrecking a C34 Laurel i bought in japan last November.
I have the motor package for sale in another parts sale thread, this is for the rest of the parts from the Laurel.
This is just part 1 of the parts i have for sale, the rest will be up in part 2 in the next couple of days. With more wheels, plenty of coilovers, and other good jap parts.
*Note for the mods* I am not running a business, this is all private sale stuff, just clearing out the parts i bought on a trip to Japan
Aftermarket Parts:
Wheels: 4x Work Reezax 17*8+30ish & 17*9+30ish - multi 4&5 stud - $900
Greddy Profec B Spec II Electronic Boost Controller - $400
3x Blitz Gauges – Oil Temp, Water Temp & Boost - brand new condition with senders - $600
Nismo Coilovers Front pair w/ Adjustable height & damper – to suit S14/S15/C34, complete with camber tops- $500
Cusco Coilovers Rear pair w/ adjustable height & damper – to suit S14/S15/C34 - $350
Momo Race steering wheel with momo horn button - $150
Nissan Boss Kit with alloy steering wheel spacer - $50
Recaro reclinable seat, with recaro rail to suit C34/S14/etc. - $500 with rail
Locked (welded) R200 diff - $300
Apexi ECV (exhaust shut-up flap thing) - $80
3” De-cat pipe - $50
3” cat-back exhaust to suit C34 - $150
Factory Parts:
C34 Front X-member (perfect for putting an RB straight into an S13/s14/s15 - $300
C34/s14 4 stud Front Hubs with twin spot brakes & a/m pads - $400
C34/s14 Steering rack – good condition - $150
S14/S15 tie rods & tie rod ends with rack spacers for more lock (brand new!) - $100
S14 front LCA’s - $250
C34 Rear Cradle (Non-hicas) also suits S14, etc. - $250
C34 Laurel Sideskirts (factory) - $100
https://www.sau.com.au/forums/topic/308084-wrecking-c34-laurel-drift-car/
keen on the side skirts, exhaust and full stereo surround trims etc
Is the car cut up yet? if not how much for the complete car minus the engine and trans?
The car is already cut. Body wise what i have left is passenger side guard, headlight, tail light. PM me if you're interested in any of that stuff.
No worries with the skirts & exhaust, I also have the factory rear pods for C34 which i'll throw in for an extra $50 if your interested.
I have most of the centre console trim stuff left except for shifter surround & ash tray, PM me an offer for that stuff if you like.
Couple updated pics...
C34/R32/etc Exhaust
Wheels (17*9's in front, 17*8's behind)
Cusco Rear Coilovers - s14/s15/C34
Momo "Race" Wheel + Horn
Gauges with looms & senders
Greddy Profec B Spec II boost controller (with loom, lines, & solenoid)
Steering shaft spacer
Nismo & Cusco coilover set is Sold pending payment.
Everything else still available
Check out Parts for sale Part 2: http://www.skylinesaustralia.com/forums/Ja...ee-t308235.html
Edited by Aussie sil80
Work Rezax wheels are now SOLD
Still Available:
Nissan Boss Kit - $20
  • 1 month later...
hi mate, i'm looking for some items if you keen to part it out:
1. throttle control unit
2. throttle motor
3. throttle motor sensor
4. throttle position sensor
please PM me, text / buzz me at 0420905342, or even email me: [email protected]
i really need these stuff, asap. so show me what u got.
thanks
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
