Heys guys,
um jus brought a garrett 2530 last week with hks snail. and been readin up on the different turbos and kinda looks like the hks is the way to go! so now im un sure as to wether i should sell the turbo and get the hks! havent put it on yet as im currently in the process of rebuilding my rb20! all gunna be ready for skyline nationals! but if could please just get some advice on what turbo is better!!
cheers guys!
  • Replies 72
Don't think there is such a thing as a Garrett 2530, if there is it would be extremly small, smaller than a standard RB20 turbo. HKS 2530's are just a Garrett 2860 chra with HKS housings(apparently flow slightly better). The 1st series still have all the usual Garrett stamps from what I have heard rather than HKS but the 2nd series has HKS labelling. Great turbo for an RB20/25 if you aren't chasing big power by the way. I have one on an RB20 and its almost as responsive as standard with 210rwkw.
Edited by Kwyjibo
hmmm the guy i brought it off said its a garrett 2530 reckons good for 230rwkw with a remap and a tune! but from wat im hearing really not sure. so yeh i wonder wat it is then lol. might have a better look at it see if theres anymore stamping on it! paid $1300 for it with braided oil lines
i dont think they woulda done a garret 2530, what does it say on the build plate?? 2530 in hks language would be a garret 2860, like kwyjibo said it would be very small
i had a HKS2540 on my 34 gt-t made 250rwkw. which by the way is for sale if your gonna buy a HKSturbo hehe little plug there :D
ill giv u 200 bucks, let you know how it goes too lol
throw up a part number off the ID tag so we can help work out what it is. HKS turbos are built from garretts so nothing new.
so i jus checked the build plate says GT2530! so guessing its a HKS 2530 with a garrett front housing! been told garrett made the front housing for them! that sound right?? oh yea the guy i got it from reckons would run safely on bout 19 or 20psi! not sure how true that is either!
im very intrested in this thread, So if i wanted a HKS 2540, but instead of me geting a HKS it would be comparison to a Garret 2860?? hmm
Man you are the excitable type arent you lol, I thought you were happy with your hypergear??
If you have the part numbers to the core and housings you want you can order the turbo through GCG. Example, call and give them the part number for the 2860R-10 with a .60 AR front cover and nissan RB specific .63 rear housing, you will end up with something extremely similar to a HKS GTRS
differences would be the HKS exhaust housing is probably better suited to the application (the GCG one is a VG30 reproduction i believe) and the HKS comp cover is port shrouded.
Make some phone calls and report back to us Geraus :thumbsup:
Giggity Giggity
hehehe, yeh i am happy, but i dont know i was watching a you tube video and the HKS GTRS sounded very and looked very responsive...... So if i wanted a hks 2540, what would i say to the Garret shop guy?? do i say 2860?
commonly known at 18-19psi to go 230rwkw on rb20's
couple people pushed the limits of it to 240rwkw which i got with supporting mods
search, millions of topics on its power and response, awesome turbo for straight bolt on bang for buck
ahk sweet! yeh im currently rebuilding my motor! getting bitta work done to the head, race bearings forgies and etc... probs gtr injectors and z32 air flow meter! so 20 psi bout 240rwkw??
2540 would be a garret 2876 I think
2530 would be a Garret 2860 I think
if the 2540 is a 2876, i dont think it would be all that RB25 friendly, a 76mm comp wheel on such a small turbo is just going to see it die too early in the rev range... while the 2530 is actually a smaller turbo its also not going to max out the hotside as quick.
food for thought.
More facts .
HKS don't make turbochargers , they get Garrett to do that .
Some time back HKS had Garrett make up turbine/compressor ball bearing cartridge combinations and had the exclusive rights to sell them . If Garrett happened to have suitable housings HKS used them , if not HKS had unique ones made to suit the application and the Garrett supplied cartridge .
Garretts turbo/cartridge numbering system has changed over the years and a good example is this GT25xx thing - ie GT2530 . Back when these turbos were new all the GT25 and GT28 series turbines were called GT25 , this is where the "GT2530" got its name though technically they are a GT2860R .
The only unique thing about the 446179-21 cartridge is the compressor wheel which is 60.1mm OD 63 trim . Garrett sell a couple of cartridges with very similarly sized compressor wheels only in 62 trim . The one from the GT2860RS has the greatest tip height AFAIK and probably performs very similar to the HKS spec Garrett GT2530 .
Different applications with the GT2530 means different housings , what suits in TT form an RB26 wouldn't suit an RB20/25 .
The single GT2530 for RB apps tends to get a generic Garrett T04B 0.60 A/R compressor housing , they make it a simpler bolt on by machining off the truck housings snout and bolt on an adapter to suit the OE rubber inlet hose . The GT2860RS usually comes with the same housing in unmodified form .
HKS had their own integral wastegate turbine housings made in T25 and T3 flange . The T25 style one has the Garrett style dump pipe flange where the T3 flanged ones were designed to suit the RB20/25's std dump pipe flange , again to make them a bolt on unit .
The HKS GT2540 is literally a GT2530 but with a 76mm T04E 46 trim compressor . You could call it a "GT2876R" but I reckon that would confuse people with the POS Garrett call a GT2876R . Neither is really a sparkling turbo but the T04E compressor is along more modern lines than the S or TB41 , don't remember which , the Garrett GT2876R has . HKS replaced the GT2540 with the GTRS which is a GT2871R 52T in HKS housings , actually the compressor housing of the GTRS in a HKS special port shrouded one in RB20/25 form or Garrett ones in SR/CA/RB26 apps .
Cheers A .
    • Thanks for all the replies fellas. Gonna finish putting it back together and see how it handles the set up. If it starts pinging it’ll be parked.
    • Well, I can recommend the partial AV system translation CD I ordered from Car Audio Workshop in NZ. Whilst it didn't address the date issue, it has conveniently translated on-screen menu items into English, and now allows the GPS-received time to be offset in hours rather than minutes, so I can display Eastern Australian time accurately ( and bump it by another hour when daylight savings starts ).
    • Yuh, if it's 45°C outside, my car is driving in it.
    • I'd be curious to hear more. Otherwise, have you driven a modern x-trail? I wonder how it compares. Here in Australia they are/were popular for rentals and fleet vehicles. I have been in some and my impression was they are bad. But, this may have been very different in the 2000s at a good trim level. Twenty years is plenty of time to make the model worse. I do very much agree with the 2 silver cars in the garage approach. But, not driving because it's too hot would not leave a lot of time in the year for many Australians. I don't think you need to worry too much unless the car has actual issues with overheating.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
