Hey guys, I have a Silver S2 R33 Skyline in Sydney for wrecking. It's been hit on the front left so headlights, guards, bonnet etc are gone. Rest of the car is available though:
I can post anything, or pickup available in Sydney
Aftermarket stuff:
Splitfire coil packs SF-DIS-005, suit S2 R33 rb25det, R34 GTR rb26dett - $450 posted
Apexi AVCR (black) with blue/white text. Great condition, includes all solenoids and a few bits of paper with the box - $450
Apexi PowerFC to suit ECR33 - $1100 ono
Nismo clear indicators - R33 - $50
Z32 AFM (with plug) - $200
GCG high flow R33 turbo with HKS actuator. Good condition with minimal shaft play - $1200 ono
post-35556-1266923885_thumb.jpg post-35556-1266923951_thumb.jpg post-35556-1266923970_thumb.jpg
Sard 550cc side feed injectors - suit rb25, sr20. Include plugs. Good condition, removed from the car about a week ago - $450 ono
Catch can, fully sick chrome. Includes hoses! - $60
Tomei 256 in/ex poncams, 8.5 lift. Suits late '97, '98 S2 R33 (with the black CAS) - $750 ono for the pair
Catco hi-flow cat, suits R32 and R33 - $100
Tein height and damper adjustable Control Master Flex coilovers, suit R33 Gts-t.
Rears are still on the car so only fronts are pictured. Theyll be out asap - $1000 ono
Walbro GSS-324, 255 L/hr fuel pump in R33 cradle - drops right in! - $120
Front strut brace - $90
Trust Pe-2 3" stainless steel catback exhaust, suits R33, great condition (pickup only!) - $500 ono
HDI Front mount cooler FMIC. 600x300x75, 3" inlet/outlets - $250 ono
OS Giken adjustable cam gear, suit RBs - $120
Blitz FATT - full auto turbo timer, black - $50
Rear strut brace - $100
Stock/Nissan parts:
Engine stuff:
R33 5-speed manual gearbox. Good condition, shifted well / no crunching. car had approx 148k k's. Includes tail shaft + yoke, shifter, crossmember - $1200 firm.
Standard airbox + snorkel. Mounts at the bottom are a little bit cracked. I fixed one of them (see pic) good for clearing defects or whatever - $80
R33 alternator - $100
Engine Mounts - $80
Fuse box lid - $20
Washer bottle - $20
Radiator overflow bottle - $20
S2 Aircon Condenser - $100
S2 ABS unit/pump - $100
BM-44 ABS brake master cylinder - $75
GTR BOV - $70
Stock BOV - $40
Cam angle sensor, late '97 style (black CAS) - $60
standard turbo oil/water lines - $50
Exterior/suspension/driveline:
Front series 2 grille - $50
Rear 'Skyline' garnish (KR4 silver) - $50
Drivers side wing mirror (KR4 silver) - $50
Tail lights (KR4, silver) - $50 each
Boot with S2 spoiler (KR4 silver), pickup only! - $100
Rear bumper (KR4 silver) - $50
Standard side skirts, genuine (plastic, KR4 silver) - $100/pair
S2 indicator/fog light - drivers side, crack in the side of the housing - not that noticible - $50
Front Calipers - $270
Rear Calipers - $150
Front rotors, good condition - $50
Rear rotors, good condition - $50
Front lower control arm (left side only) - $70
Front upper control arms - $50/pair
Front hubs - $150/pair
Rear lower control arms - $50 each
Rear 5 stud hubs - $150 pair
Handbrake assembly & cables - $160 pair
Manaual (4.11) ABS diff - $250
Driveshafts $50 pair
Rear upper arms - $50
Interior stuff:
Drivers side window switch surround - $50
Passenger door motor - $50
S2 door trims, full set (front+rear) good condition - $100
dash + gearstick surround - SOLD
Glovebox - $30
Series 2 dashboard (with passenger airbag & panel) - $250
S2 Steering wheel with airbag - $250
Climate control - $50
S2 Front seats, good condition. Small wear mark on the drivers side where you get in - $180
Seatbelts, full set - $80 (will seperate)
Ignition barrel + door barrels + key - $100
Wiper & indicator stalks - $40
PM me if youre after anything :P
  • Replies 88
"Splitfire coil packs SF-DIS-005, suit S2 R33 rb25det, R34 GTR rb26dett - $450 posted"
If these fit the S2 RB25, they wont fit an RB26 will they?? S2 hasn't got a separate ignitor like S1 or RB20/26, i thought all RB26's had separate ignitors....im not 100% on this, just asking the question.
32 and 33 GTRs have the separate ignitor but R34s don't :ninja:
PM Sent
PM replied
Do want GCG :P just gotta try and scrape together cash...
No worries, PM me if youre keen.
Grille sold pending payment
S2 r33 coil packs are the same as the R34 GTR rb26
Hi was hoping you still have the drivers side power window switches and if so could i see a picture of the back as there is are different ones
I need the spec 2 with the white plastic backing NOT the black
Thanks
J
PM box cleared, was full for a few hours before
Hiflow, grille, cam gear sold
Don't have a aircon/heater blower fan do you?
Bolted to bottom of air box.
PM back if so. thanks.
Pm sent
PM Sent
replied
Thanks
J
Sorry mate I sold the drivers side switch already
pm sent
Replied
heya can u PM me a price for just the passenger front seat?
Sorry mate just looking to sell them as a pair at the moment
Im after stock suspension can ya help us out?
Sorry mate I only have the coiloivers
PM Sent
Replied
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
