seriously.... ?
NO
pfft man i dont know. dont start another Spark Plug session. lol nah hers is stock, its probably just as thin as ours. might do some sourcing later on for an After market one.
  • Replies 234
Posted Images
When fitting a larger radiator, you need to cut the black "glassfibre composite" frame that it sits in
Ohh yeh like what Scott had to do?
should be too hard of a job right? In all honesty, what will the bigger radiator acheive? will this only make a difference if the cars tuned?
What do you think a larger radiator will achieve?
Better cooling control for one, especially when you consider that the stock core is only 16mm thick lol.
Not too difficult if you are happy to take to your car with a hacksaw.
I still had to hack up a fair bit to get my custom radiator in after I lost my nerve (and patience) with the Mishimoto unit that now resides in Scott's car
Edited by iamhe77
hmm.
16mm thick? more like you could fold it and make a paper aeroplane. i do see what you mean. is there a thread explaining this more? eg prices brands dimensions etc? might be worth looking into
hmm.
G35 radiators from the US... or a Z33 radiator that will need to be modified (cap needs to be moved and mounting "pegs" may need to be moved.
Make sure they have an in-tank cooler too.
That is all
For a custom one? I took my stock unit to Race Radiators who made me on up using a Griffin Race core and has them put the OEM in-tank into the custom unit.
Lovely unit and they do great work.
I still have my stock radiator if you want to go this route - but it will probably cost you more than buying a Chinese Z33 core and having it modified.
not really but we should start one on m35stagea.info
When you put yours in, feel free to put up a good "How to"... which reminds me, I really should do that transmission service post...
That is all
hmm might look at the G35's from us seeing as the dollar is still pretty good. its a pity no one has really made after market products for our cars :D
Has anybody gotten on to PWR and asked them to make something custom? with intanks and outlets n blah blah blah?
Edited by AaronNM35
hmm might look at the G35's from us seeing as the dollar is still pretty good. its a pity no one has really made after market products for our cars :(
PWR do a G35 radiator.
I spoke to them about a custom radiator and even measured up the stock one, but $1k + shipping with a possibility of it not fitting is not a risk I was prepared to take.
On the positive side, I believe that their G35 radiator retails for under $650USD... in the US, so should be significantly cheaper here you would think....
....BWAHAHAHAHAHAHAHAHAHA
Edited by iamhe77
what does the nismo thermostat open at ?
i know the r33's doesnt even think of opening until circa 79C anyway. more than likely the same principle applies.. meaning theres no flow around the engine until your hitting that temp anyway.
sometimes no thermostat is better.
im thinking 90C even though its not far off boiling temp.. isnt that far fetched for the running temp of this engine.
Edited by PetroDola
No thermostat, is almost always worse, car takes forever to heat up, if it ever does. Rich fuel mixture uses heaps of fuel, as you never get out of cold start map, washing oil off bores, allowing rings to score everything. Not a single good thing there...
Don't forget your cooling system is pressurised, water will not boil at 100deg, under pressure.
Edited by Daleo
good point!
im too used to working on older v8's daleo that dont have computers and run hot normally. so different principle i guess.
well then a lower temped thermostat should be sufficent then ?
Edited by PetroDola
I'm not really a fan of those either, in extreme cases they can cause similar problems to no thermostat, if the opening temp is low enough. You're only masking issues of an inadequate cooling system, either not enough water volume or not enough heat shedding ability. Both of which you can correct with an appropriately sized, well designed aftermarket core.
scott said to go where you went :( he said its a little more but they make sure it fits which i wouldnt mind spending the extra couple of hundred on, if that
Nismo thermostat opens at 68 degrees. The stock one opens at 78 degrees.
Cheers
Andy
on the nismo site it says it opens at 62c and standard nissan Thermostats open at 76.5c. I wouldve thought 62c would be abit cold right?
scott said to go where you went :down: he said its a little more but they make sure it fits which i wouldnt mind spending the extra couple of hundred on, if that
It is a little more that a Chinese unit, but they use great core's, workmanship is of high quality and a full custom radiator for just over $700 ain't too bad IMO.
PLUS I still have my old one which you can take to the to use as a template (to in-tank trans though - it is in my current radiator)
68c
I guess you were looking at a US site?
The Mishimoto VQ35 thermostat opens at 62c... which causes all kinds of issues for our cars, doesn't it Scott!
There are a few of us running the Nismo units with no issues whatsoever. Mine has been in for over a year and a half with no concerns :D
68c
There are a few of us running the Nismo units with no issues whatsoever. Mine has been in for over a year and a half with no concerns :down:
i thought i'de just have to give them the car and they make and install. using the one in the car as a template. i'm not too comfortable with doing something like the radiator by myself. i know it isnt a big job. but still new too it i dun wanna f**k anything up.
i duno it was a Nismo official site though. i wouldve thought if it was american they wouldve outlined temps in farenheit(or however its spelt) but they said 'C'
$700.00 for a radiator(for our car) i would be happy with. cant find anything for our cars easily or cheap .. whats IMO lol
Edited by AaronNM35
    • Prime parking, she is a little girl...LOL
    • I'm actually not sure - I think it was "Stealth Performance" (It really is near impossible to find a FEMALE 1/8BSPT to 1/8NPT male at ALL) but having the thing leveraged on a 90 degree angle on a small aluminium fitting is not too smart. Also in not too smart, I've drilled out the center of the broken fitting so there's maybe 0.00001mm of thread to bite into, so yeah. I may have to get it drilled/tapped/plugged entirely. Given I could conceivably tap a thread/adapter/pressure line in any point in the oil system I suppose it's feasible to run a line to the Nissan Sensor to keep the dash working. Do these exist in AN fittings and the like? Like an AN fitting that has a NPT (or other?) thread as well for putting a sensor in?
    • I would agree.  There will be an amount of boost you could run safely with an otherwise factory system, but it would be low enough to not be worth the cost.  And if you are reliving your 20s, you know a 'little bit' was never enough. Personally, if I didn't want to spend the money, then stick with NA bolt-ons, and maybe a tune.
    • Fuark, at least the motor survived. What brand was the fitting that snapped?
    • Wrong question. There's no point in spending the rather large sum of cash and effort to add turbo, without taking it to the "sensible" limit of the motor itself. If you have to upgrade injectors, etc, then so be it. That is a tiny fraction of what it will cost you to turbo it.
