Hmmm... Thinking about buying an R34 GT-4. How easy is it to do an engine swap? Drop in an RB26 and it's essentially a GTR..
Never seen a GT-4 for sale until now. $15k asking price.
As what Shan said...
You could probably get a R32 GTR for a similar price of a R34 GTT.
Or save your money and get the MR2 Turbo.
Yeah I think I will get a stock MR2 turbo. Less cop hassles that way.
Also thinking of getting a shitbox Celica for like $2000 and save all my money for other things (not necessarily cars).
I might take a break from the car scene... We'll see what comes along.
Get an R32 GTS-4 and be a winner like me :ermm:
mine's for sale if you want it.
can supply with stock go fast bits or not depending on how ethnic you get and try to haggle.
comes in 6 different body colours simultaneously.
two owners since new with full books. both owners liked teh go fast pedal.
hahah the abs f**ked up on my gts-4... sounds like someone has had the 4wd fuse pulled out for too long, or has been doing rwd keybangers
mine f**ked up soo badly i coudnt even turn a corner, it would just lock the attessa half way between and it was like jaming the breaks on while trying to perform a u turn hahaha
nah mine just has one caliper locked permanently. It compresses, but then doesn't flow backwards. Guessing there's something in the ABS lines that's acting as a one way valve. Gonna bleed it n see what happens... just need to get around to doing it.
Err.. Your manual comment is void because I CAN drive manual. Would you like to see video of me driving my workmate's MR2 tomorrow? Major inconvenience but I can do it on my lunch break. Would be worth it to prove you wrong... :(
FYI, I don't want to have internet arguments. They're gay. So after this reply just leave it kthx.
Oh and I have driven SAU people's cars before. First one I ever drove was Chad's 32 and he will back me up if he reads this.
If I managed to handle that clutch I'm pretty sure I can handle a standard one :(
If I managed to handle that clutch I'm pretty sure I can handle a standard one :P
wow panties in a bunch, post up saying you don't like internet arguments and you keep goin on fb and SAU :P nice.
lol standard. yes :(
never go into first gear
only go into first gear when you are stopped
if the vehicle is moving, the lowest gear you should select is 2nd
again this would be from sub 30/40km/h
you dont need to downgear in sequence but dont go from 4th to 1st or 2nd
theres too much ratio difference. if your in fourth and slowing down, goto 3rd and brake a bit
use both to slow the car down. not one. if you stick with using one (ie engine or brake)
when you need to emergency stop you wont clutch in, which will mean the car wont stop for peanuts
in an auto when you brake, the engine is disengaged from the clutch, so you stop normally
if you do the same in a manual ,the car will pull up heaps slower and take much longer, cos the engine and clutch are still engaged. ie like slowing down a spinning wheel whilst someone is still pedaling behind on it (on a bike)
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
