Hmmm... Thinking about buying an R34 GT-4. How easy is it to do an engine swap? Drop in an RB26 and it's essentially a GTR..
Never seen a GT-4 for sale until now. $15k asking price.
As what Shan said...
You could probably get a R32 GTR for a similar price of a R34 GTT.
Or save your money and get the MR2 Turbo.
Yeah I think I will get a stock MR2 turbo. Less cop hassles that way.
Also thinking of getting a shitbox Celica for like $2000 and save all my money for other things (not necessarily cars).
I might take a break from the car scene... We'll see what comes along.
Get an R32 GTS-4 and be a winner like me :ermm:
mine's for sale if you want it.
can supply with stock go fast bits or not depending on how ethnic you get and try to haggle.
comes in 6 different body colours simultaneously.
two owners since new with full books. both owners liked teh go fast pedal.
hahah the abs f**ked up on my gts-4... sounds like someone has had the 4wd fuse pulled out for too long, or has been doing rwd keybangers
mine f**ked up soo badly i coudnt even turn a corner, it would just lock the attessa half way between and it was like jaming the breaks on while trying to perform a u turn hahaha
nah mine just has one caliper locked permanently. It compresses, but then doesn't flow backwards. Guessing there's something in the ABS lines that's acting as a one way valve. Gonna bleed it n see what happens... just need to get around to doing it.
Err.. Your manual comment is void because I CAN drive manual. Would you like to see video of me driving my workmate's MR2 tomorrow? Major inconvenience but I can do it on my lunch break. Would be worth it to prove you wrong... :(
FYI, I don't want to have internet arguments. They're gay. So after this reply just leave it kthx.
Oh and I have driven SAU people's cars before. First one I ever drove was Chad's 32 and he will back me up if he reads this.
If I managed to handle that clutch I'm pretty sure I can handle a standard one :(
If I managed to handle that clutch I'm pretty sure I can handle a standard one :P
wow panties in a bunch, post up saying you don't like internet arguments and you keep goin on fb and SAU :P nice.
lol standard. yes :(
never go into first gear
only go into first gear when you are stopped
if the vehicle is moving, the lowest gear you should select is 2nd
again this would be from sub 30/40km/h
you dont need to downgear in sequence but dont go from 4th to 1st or 2nd
theres too much ratio difference. if your in fourth and slowing down, goto 3rd and brake a bit
use both to slow the car down. not one. if you stick with using one (ie engine or brake)
when you need to emergency stop you wont clutch in, which will mean the car wont stop for peanuts
in an auto when you brake, the engine is disengaged from the clutch, so you stop normally
if you do the same in a manual ,the car will pull up heaps slower and take much longer, cos the engine and clutch are still engaged. ie like slowing down a spinning wheel whilst someone is still pedaling behind on it (on a bike)
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
