f**kin dog wakes me up at 7am, and doesn't have a snooze button.
yeah VIC wasteland has gone to the shits, used to be epic... then again, we all somehow got busy around the same time. plus facebook became the new wasteland.
she works for etihad in dubai.
i would like for my genitals to meet her genitals at one stage. don't tell her i said that, i'd like it to be a surprise.
sounds like someone is on stalker book...
yes, she does appear to be living the dream on stalkbook.
got a fav song at the moment with a great line that goes "theres nothing finer than having a vagina" its called my vagina by nofx. great band. i love finding songs that i forgot about until you find the cd again at your brothers place, lol dont know how it got there.
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
