It's gotta be a 32R Dezz and you know it! Such a tough road stance. I love a R34 GTR as well... but there is always something about a R32 that just makes you go "mmm"
You'll pay through the nose for a clean one though is the only issue :cheers:
They are appealing to me, but there is the age factor...I'd probably only buy a decent example, or a stock one for less and plan to do what I did to my 33 and more...
There's an absolute shit load of 32R's for sale at the moment though, so it's becoming more of a buyers market...The only ones that will get their price are the ones that don't need to sell.
haha i tagged you in it ages ago
Ah yeah that, that's porn. thought you meant 35GTR
Yeah there are GTR's fken everywhere :cheers:
Age factory is indeed a problem. You'd be looking to buy one that's already had someone dump their bank account into it IMO.
Someone i know sold a mint R32 GTR (heavily modded) for over 30k.
So the exceptional examples are still fetching good money, but then it's money well spent as you'd never need to change a thing on such examples really.
Yeah I saw a few of the better known 32 GTR's for sale not long ago...Archie's I think was up there...all asking big coin, but pretty much everything done...Still, there's 33's going for similar money with all the fruit as well.
http://www.skylinesaustralia.com/forums/19...Co-t298244.html
That looks decent, apart from the color which I'm not a big fan of...
If I did go the 32 route, and chose a modified one, a forged rebuild at a reputable workshop would be high on the list of already done mod priorities..
I've started to consider 33 GTRs myself. I've found that most of them are actually cheaper than 32s! At least on the JSPEC featured list.
It would have to be black though. Was never the biggest fan of 33s but in black they look quite acceptable.
There's a wingless one for like 17k landed and complied.
Anyone know what a 34 GTR wing would look like on a 33?
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
