fuck that, its an SR20. drive it till it dies. then buy another one. This kent and his forged obsession, fuck off with that "I have forged internals" braggery BS.
If you're dailying an SR, boltons are the way to go.
don't u run a 2530?
haha nope, my turbo bigger than a 2530
custom made garret one, uses a 33 comp cover machined all the way out and a AVO .73 exhaust housing
pretty much esentially a GCG rb25 hiflow the size
yeah same goes with all engines, drive them till they need it
otherwise u pay big bucks for nothing
yeah thats the price im looking to spend 18-19k.
At the end of the day all i really want is a straight pipe and gangster fittment.
hah buy a standard one and put straight pipes and hellaflush fitment then :blink:
Haha typical! Wouldn't expect anything less from you :blink:
Will be good when you've got a car again. I'm always down your area now. Can do some carwash meets and shit lol
chad if you gots cash moneh ready let me know, there's always kids comin in the shop wanting to offload cars cheap to pay off loans etc cos they can't afford the baller status anymore. You'll need 16k minimum tho.
also pat....
$1500 = secondhand HKS2530 kit. Both Nick and I run it and get roughly 80kw boost in performance.
you just spent how much and get 30 - 40kw? and ongoing costs are how much?
lol ive already got a hks2530, rebuilt too :blink:
210kw with 15psi @ 11.5afr
I should be able to get 230kw atw with 18-19psi with 98octane
and then ontop of that will be the methanol injection which should get me another 30kw atw
Im hoping to hit 250kw atw
i listen to everything, dance/trance house, rnb, retro, 80s
just not a fan of metal, classical or country
hell yeh
ummm just ghey
he's awesome man... you have shit taste
just get a non turbo car and be done with it..
u been going on about it for ever. its gonna be like the boy who cried wolf by the time u get something..
just man up and take the plunge but go non turbo save ursefl a pulsating rectum everytime u drive for the next 3 years
if this is directed at me; i dont want an NA because i want something i can take to a track and have some fun in..
then again, if they approve it, no pulsating rectum
I want 7.5 or 8 wide at the front and 9 or 9.5 in the rear. Preferred style is 5 spoke but open to suggestions.
depends on the car you wanna put em on.
learn to walk before you try to run dicksnot.
Who said N/A isn't fun.. :whistling:
I have 4 N/A Skylines, the newest one is surprisingly fast. R32 with RB25DE.
Who said N/A isn't fun.. :D
agreed, N/A is still just as fun. are you saying that because its not turbo it wont be fun? im sure a porsche gt3 and ferrari f430 would be very fun lol.
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
