Would it be wrong to use an aboriginal word as a band name? For some reason I feel like I'm not worthy of using their language because I'm white lol...
Edited by jezza boii
what word do you want to use? im sure whatever it is it will be too hard to say and spell lol.
Alkira. I think it sounds really nice. It means "the sky". My music is inspired alot by the world around me (sunsets, beach, sky etc.) so the name really suits.
wtf... why do cnc'd titanium parts have oxidisation marks on them? that's full homo spec.
titanium + heat = oxidisation = pretty colours
titanium + electricity = electrolysis = pretty colours
titanium + cnc machine = mirror surface in a uniform colour
in fact to make a cnc'd titanium surface go magenta/green you have to etch the surface or subject it to extreme heat, which actually distresses the material and makes it weaker. This happens naturally near welds and shit, but on a machined washer and bolt? GTFO.
those washers are just anodised too look like titanium
i dont see any problems with it, i like it, easy to say and write lol. actually doesnt sound like an Aboriginal word.
id say go with it, you like it and it has a meaning to you and your music.
wtf is with all these shit sizes, harden the f**k up and find something decent.
I dislike the blue but thats personal taste, hate blue.
you find me epic fitment in 5x100 then. I'm trying to avoid running spacers, pcd adapters etc.
they come with 6.5 +30 or some shit.
After all the measurements I did I can fit 9" +25 to 9" +30 in the front with some rolling and so on. This will give me minimum offset on maximum width.
The rears aren't an issue, there's plenty of clearance and space to fit up to 11".
on the rear I'd like around 10" +25 or something like that.
this is the colour the car is atm.
Fucking euro's running gay bolt patterns and reverse mounting hubs.
That's not overly expensive.
Funky - do it right. eBay USA for some BBS's you know you want to!!
yeah i know its not
but atm for me it is haha
fuuuuuuuu
Might explain why my car has been trying to stall when coming to a stop yesterday
ive got a set of gtr injectors for sale :P
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
