Ouch. From what I remember that component of mine was about $3.5k
i suppose it goes to show everything to do with a gtr is more expensive lol. i hope im not getting ripped off though.its almost double the amount you posted.
cbf with importing though
yeh sometimes its to much hassle
all looks great but that wing, oh my f**king god
TRD wing, actually looks good if the car is modded right
evo 6s are fair cheap on jspec.....wow
yeh saw 2 for $15k landed and complied O_o cheap
there prices they have for customs fees and that cant be accurate, mine is way more than that :/ .
yours probably wasn't 685,000 FOB either
I bet in 12 weeks time from now you stilll won't have a car, even if you bought local.
good thing about importing is that you pay in stages, so initial up front cost is only like 1/3rd final cost. It's almost like a loan :P
does the customs prices vary to how much the car costs in the first place? eg. the more expensive the car the more customs tax and shit id have to pay.
scratch that question lol, of course it does. i think i need some sleep :P
Importing is good fun. What was funny is my car cost me $7200 in Japan, shipping, customs duties, compliance, rego, etc. came to more than that. It was still cheaper than buying locally at the time by at least $3-4k.
when i got the evo it worked out cheaper to buy it here
but i squeezed the people outa $4k straight off lol
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
