yeh thats what i saw when i looked
18x9.5 +20 rota grids
with a 20mm spacer on front its now 18x9.5 +/-0
and a 15mm spacer on rear its now 18x9.5 +5
ewww both these cars are running voltex widebodies, the rear quarter bolt on sections are shit as
:P this is the wastelandz you idjit. thread only ends when it get too big (approx 1000pgs) and funky makes a new one
i knooooooooooooooooooooo
miss the point much :)
yeh the te's are huge im diggin the bbs if u rock that stance though if u dont slam it like that will llook pox
why would u bother ? if u want stilts get some 4x2 from bunnings haha..
nah do it once do it right go baller cos most evo's fail that i see
haha they do, most run about what ive got now 8.5 +35 or 8 +38
the 9 +17 wil be a near perfect fit any wider/lower offset itll rub bad and i dont wana flare
get some adjustable coilovers and rise it higher, and then use it for what it was meant for and find some dirt tracks for some rally goodness :) .
i live on a dirt road, but i hate driving on it
i like clean cars, ive taken it down the road once it was soooo filthy afterwoods and dust was in everything.... never again
now snow.... thats a different story..... common winter :P
now snow.... thats a different story..... common winter :)
im the same, i hate hearing the stones flick up and you hear them hitting your car, it makes me cry.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
