Yeah, I won't be getting Meisters. I only want to spend about $3000 max on wheels + tires.
So what do you think of the overall look of that car Shan? Coz that's my inspiration for this project.
But unfortunately I won't be pulling 330rwkw like him :( Otherwise I could buy in on this "my dick is bigger than yours" contest between Kris and Hamish :ninja:
second hand meisters/professors will set you back under that...
enough rice talk.
Who here has 1x GTR injector willing to let go of?
How much would Nissan charge for 1x GTR injector? $100-$150?
farken heaps.... they quoted me $450ea for s15 ones
just puttin it out there best evo ive seen.
dont like meisters/professors on evo's... dont really know why...
had a look and there is only one black one running tuff fitment, but the way its done makes it nice
mmm i like sp1's but jsut not on an evo
needs a racey sorta wheel i reckon like te37, xd9, xt7, ce28n
+1
mmm also found some cr kai in 17x9 +17 so if the xt7s fall through have them as well
this was the wheel you always wanted for the evo wasn't it?
cr kai are shit dont do it.
you are ghey... gtfo
evo drivers in oz amuse me. they're either asians who have watched a bit too much initial D, or white boys who are WRC fans. the ironic bit is that both stereotypes are so protective of their precious cars that they won't take it hillclimbing etc and sit there stressing about a chip on the paintwork.
fuck off you sandy vagina'd poser douchebags. your car is not the fucking automotive messiah, it's a fucking lancer with a turbo and an extra LSD. you don't have fucking active yaw control so that you can better negotiate roundabouts. drive it like it was meant to be driven or give it here and walk to your fucking knitting lessons or book clubs or whatever fuck you ballbagless eunuchs seem to like doing for fun.
bahahahahaha sooooooooooooooooo accurate
+11ty
great story hansell.
thanx oolof
Harden the f**k up and get the 18x9.5 +12's
/thread +1 LOL
+1
i could go some 18x9.5 +30 xt7s would cost about $1200 plus shipping brand new
and any of the xt7 in 18x9.5 regardless of offset are deep concave, a +30 with still sit nice on car
i hate how you are a ghey
Can someone please help me to find wheels? Everywhere I look they're like $3000+ for wheels and no tires + in the wrong offset.
I need...
Front:
17"
7.5" wide
+29
Rear:
17"
8.5" wide
+29
Those figures = exactly flush.
can't decide if I want a Viper 5902 or a 5901. 5902 has 2 car support (same remote for 2 alarms) which would be good for the 32 and the golf.
altho 32 already has an older viper which doesn't work with the remote so that feature is useless :\
5901 is $100 cheaper and isn't as obnoxious (colour screen, ringtones... wtf) might go with that instead.
I need...
Front:
17"
7.5" wide
+29
Rear:
17"
8.5" wide
+29
these are 17x8+29 and 17x9+38
the fronts will sit out by 6mm and the rears in by 3mm
or if you use a 10mm bolt on spacer sit out by 7mm
they are $1800 from j-imports.com.au
whats wrong with a tyre iron? always tryin to be all hollywood with flash gizzmo's
Thanks for that man :( They look alright. I like CE28Ns and TE37s better though.
I used a calculator and it said
Your proposed front wheel will be 6.35 mm farther out than flush (flush offset: 35.35).
Your proposed rear wheel will be 2.65 mm tucked in from flush (flush offset: 35.35).
So you were pretty spot on :ninja:
Edited by jezza boii
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
