RPM = (SPEED / 28) * 1000
it looks to ramp at 3900rpm
would be good for the street
Awesome, posted it mainly for you to see paul :)
It goes a lot better now, crazy when it comes on boost :)
Just gotta call me chaddy! Aint no problem haha
Aight, this is how im programming my thermofans
@ 80C: 1st Thermofan turns on and runs at 50% speed
@ 81C - 88C: 1x Thermofan speed increases 51% - 99%
@ 89C: 1st Thermofan at 100% speed + 2nd Thermofan at 100% speed
@ 86C: 1st Thermofan at 50% speed + 2nd Thermofan at 0% speed
@ 78C: 1st Thermofan at 0% speed
78C is a reasonable driving temperature with a 52mm radiator?
Yea i love the extra 30rwkw midrange! Who cares about the 300 now lol. Cant belive the cat was robbing me 30rwkw in the midrange. f**ked that thing off nicely lol
yeah they can get bad
chuck in some e85 and you get more power everywhere and crack the 300 :)
I get that on my stock radiator
ah yeah nice. I was getting 84deg on my stock radiator, hence why i replaced it. Used to be 80deg but slowly moved to 82deg and then 84deg. Most likely it was becoming full of crap.
Will trial 78deg driving temperature. Being Winter now, shouldnt be hard to maintain.
One thing im worried about is that my thermo-fan controller looks like an aftermarket ecu. Hopefully the cops will believe me when I tell him its a fan controller as it doesnt even say its a fan controller on it! haha
yep 80deg is ideal operating temp
the powerfc and presumably stock ECU are in correction mode until water temp is 80deg bang on
that is, it adjusts the timing and richens up ever so slightly until water temp hits 80deg
in my GTST i never get to 80deg, the problem is that annoying i had to remove the correction below 80deg
on my 33 temp correction is disabled when it reaches 50deg, as i found it would never get to 80deg bang on
so it would forever be in correction mode. now its fine and once 50deg is reached, no more correction
just chuck it into the glovebox
nah too much wiring to bring it into glovebox. Its mounted in the engine bay next to the battery.
interesting, the r32gtst retards/runs a rich map until 65deg, then switches over to the proper fuel map. So r33's bumped it up to 80deg?
Maybe you got a dud thermostat being open the whole time allowing the engine to not warm up?
In the morning, open the radiator cap and start the car. If you see water moving, then its cycling through the engine which it shouldnt be...
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
