wondering if someone answer a few questions >,<
are the tein EDFC controller universal?
and
just the motors need to be the correct ones for that type of suspension?
just want to make sure im reading this right..
ahh ignore that pretty sure i sorted it all out :D
was gonna buy from guy in parts for sale section but was r34 motor kit >,<
and for 180$ more i can get it brand new with right motor kit - *waits for tax return*
bout to watch 'Inglourious Basterds' - havent seen it so hope its good!
good: sold the hilux.
okay: its ramadan, mad food every night
bad: im so f**king hungry
eat what you want.... when you want....
the best an imaginary being can do is give you an imaginary ass whoopin
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
