shit, i'll even throw in a half shattered bodykit that makes the car sit 2cm off the ground. I've reverted it to factory plastic so I can be all like "low stance, no care".
What brides you got Alex? Pics now :D
My Recaros are getting retrimmed in the next few days. My motor trimmer talked me into doing something totally different. You guys probably won't approve but oh well :D
around that age i rkn they'd all be the same i dont recall any widescreen single din head units luls..
tried autobarns an shit? they have heaps of those pockets..
haven't yet... i was hoping for a genuine nissan one but i may have to go crappy aftermarket type.
the only one i could find easily was from a 2007 x-trail... not sure if the fittings and shit are the same..
what seat did you get mang? EDIT: beat me to it jizzy.
chasing one with a door (to hide firearms and *gasp* EBC) but they are harder to find than osama :D
you want a ceffy popout drawer, fits in any R31-R34 skyline DIN. full DIN size drawer that clicks in to lock and clicks in to slide out using a spring load. gangster as. good for hiding rubbers/ipods and shit which you want easy access to but don't want visible all the time.
try wreckers. Think Laurels, Cedrics, Cimas and Glorias also got em.
and no you can't have mine. unless you buy the car.
Retrimmed ey... what gayness could you possibly bring to us now? crocodile skin? snake skin? something gayyer?
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
