Rear guards are already rolled. Wouldn't they need to be flared though? My fronts hit the guard like a mofo and they're only sticking out 6mm.
15mm spacers in the rear would mean 10+mm out of the guard.
get the 10mm spacers then. you should be able to flex the metal 5mm pretty easily. I got an extra 10mm out of my ceffy when I rolled it. Didn't need a respray.
just sell the wheels and start again if it's all too hard for you.
also helps if you stretch tyres. I tucked a 10.5" with 225's on the back of the cef. no way that would fit without stretched tyres.
your tyres are probably scraping on the front cos you're probably running Pat spec tyres.
nice... I don't see any hub locating rings on those wheels either. And you wanted to run 5mm spacers? oh dear.
notice rim isn't even visible cos the tyre's too big? if your wheel is tucked this is how it should be, but if your wheel is mexican then you need to stretch at the bare minimum to prevent it getting cut up every time you hit a bump.
compare this to mine:
see what you need to do if you're running flush or slightly pokey wheels?
Hmm... So fronts would be better with like a 205 yeah? And a bit of negative camber? Would that affect handling?
depends. if you like drag races only then it's bad. if you like cornering then it's good. if you like tyre longevity then GTFO.
more pressing issue would be to get some hub locating rings on those wheels. atm the only thing holding them in place are your lugs.
haha yeah, that's the other thing - if you go hub centric spacers then hole in the spacer need to match the hubs and the ring on the spacers need to match the wheels - or run hub rings as well as spacers
But did the rings match your hubs or your rims?
I bought ones to suit an MR2. So I guess?? 60.1 is the number I was told to order.
I really have no idea what I'm talking about, as you can guess.
Edited by jezza boii
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
