Rear guards are already rolled. Wouldn't they need to be flared though? My fronts hit the guard like a mofo and they're only sticking out 6mm.
15mm spacers in the rear would mean 10+mm out of the guard.
get the 10mm spacers then. you should be able to flex the metal 5mm pretty easily. I got an extra 10mm out of my ceffy when I rolled it. Didn't need a respray.
just sell the wheels and start again if it's all too hard for you.
also helps if you stretch tyres. I tucked a 10.5" with 225's on the back of the cef. no way that would fit without stretched tyres.
your tyres are probably scraping on the front cos you're probably running Pat spec tyres.
nice... I don't see any hub locating rings on those wheels either. And you wanted to run 5mm spacers? oh dear.
notice rim isn't even visible cos the tyre's too big? if your wheel is tucked this is how it should be, but if your wheel is mexican then you need to stretch at the bare minimum to prevent it getting cut up every time you hit a bump.
compare this to mine:
see what you need to do if you're running flush or slightly pokey wheels?
Hmm... So fronts would be better with like a 205 yeah? And a bit of negative camber? Would that affect handling?
depends. if you like drag races only then it's bad. if you like cornering then it's good. if you like tyre longevity then GTFO.
more pressing issue would be to get some hub locating rings on those wheels. atm the only thing holding them in place are your lugs.
haha yeah, that's the other thing - if you go hub centric spacers then hole in the spacer need to match the hubs and the ring on the spacers need to match the wheels - or run hub rings as well as spacers
But did the rings match your hubs or your rims?
I bought ones to suit an MR2. So I guess?? 60.1 is the number I was told to order.
I really have no idea what I'm talking about, as you can guess.
Edited by jezza boii
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
