chasers?
Nah, the mechanic opposite my work who does all of my cars now. Honest, knowledgable, reliable and cheap. Not giving his name out publically though as they're a two person shop and already have plenty of customers to keep them busy. PM me if you want the contact details.
It doesn't take a lot of effort to find something unroadworthy/illegal on a skyline. Your restriction is just another headache ontop haha.
i know, its quick enough for me at the moment, loving how east and effortless it is to drive.
im also very surprised with the condition of it, the floormats are still in excellent condition! lmao
also found this inside it.. what is it?
of course, you were meant to do that before you bought it
correct, put it in my mums name lol
lol, he wont listen to anyone his like me when I was that age, I was a fraction away from buying a 32 GTST but good thing I didn't the first week of owning the N/A got pulled over and checked for turbo etc.
All the best with it Mohsen, if you get f**ked by cops just buy another car straight away.. keep the 32 in the garage for 4 years. Then it will only be a 25 year old car :down:
thanks dude, hopefully i dont get any hassles, its not like i drive like a manyak or anything.
im not gona drive it on far untill i get an exemption too.
edit:
kinda what i want my car to gradually look like, minus guards
Edited by Mohsen
Looks like a 0-100km/h & 0-400m timer. Records how long it takes you to achieve either one.
no, i need to get my p's first
Why? I don't remember any part of the rules saying you have to be on your P's to ask them if the car is legal or not.
i actually rang them and asked them. they said i have to have my p's before they allow it.
finished the stupid logbook, just have to book them and go for the test.
also, shan, would you know where the valet switch is
in the boot...
i read somewhere theres a little lever for when you want to open the boot with a key or the pulley thing.
the pulley thing wont work and someone said its the valet switch/lever. DOING MY HEAD IN
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
