my sessions go for 10-15 mins. I jump on the Age site and catch up on the latest news.
about as nasty as people who groan/moan while dropping a mother load.
I don't make noises. I'm well mannered like that.
Lol fair enough. Do you like MR2s? :(
yesh, i was considering buying one when i sold my last skyline
y'all ngas is gay.
seriously, you guys sound like you'd enjoy JO'ing each other while making eye contact.
do i hear jealousy?
100% will play he keeps raging at me hard anyway cos im bronze he is diamond = we get raped.
LOL
ps. saw your post in other thread you work for henley?
so so jelous
not only am i bronze, but im bronze rank 27 boya top that :(
i used to work for henley correct
drove my car to school today... the teachers shook their heads when they saw it hahaha
did you have your cap sideways and flat? and then hold your hand up and sideways in an E shape?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
