probably a mock up :(
i've only ever seen 1 on the road. bout 5 years ago lol
sti > evo :ninja:
pffft your opinion fails :)
lol. in other news i got my new bushes for the gtr, also my new metal cat arrived from boost bitz, it looks really good and at a good price also aussie made, now all i need is the front pipe to finish it off.
we spoke about this..... straight pipe remember?
Pffftttt evo shits on sti!!!
bad :D
pffft your opinion fails :D
bad :(
im caveing in to peer pressure lol. the problem is my exhaust tip doesnt stick out from the back so all it will do is make a mess on the back and burn that lovely paint.
black/carbon exhaust shield will help a bit :(
briefly owned a Evo 6 Tommy Makkinen and it was a blast to drive. drove one of the evo 7 we imported for a mate and it was disappointing compared, even with the extra yaw control... drove a evo 8 rs and it was balls out fun, but i'd never use it off a track cos its just a rally car shell.
after evo 6 the only good evo is a stripped out race evo. 7 upwards just try to do too much.
yup, stick a nice resin coated piece of cloth next to a pipe that's hot and occasionally shoots flames.
you're a fuckin genius.
aluminium sheeting to protect bumper and rivets to hold it on. kgo.
once the resin is dried its going be the same effect as having the bar there
if its going to catch fire its going to catch fire (bar or the exhaust shield)
considering the showie nature of his car doubt he going to pop rivet into his rear bar
yeah i wouldnt pop rivet ill probably cable tie it on lol.
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
