Was told splitfires are the best, wouldn't know cos I never had coilpacks fail on me.
I now have a dilemma once again, this time whether to sell my R for built one or not...
you have a stock skyline. find out how many shit coilpacks you've got using that process of elimination described before, then buy some secondhand ones and swap em in (only the ones that are dead). you can look at aftermarket coilpacks when you start pushing serious power.
if you buy a full set of 6 or 3, you'll end up with a couple of spare you can swap in later when the other die. will cost you about $60. That's how much it cost to fix the missing spark on my ceffy... 3 fubar coils.
how much would you sell for?
give me a factory spec gtr over a built one anyday
$23k, have modifications such as hks gt-ss, power fc, cusco coilovers, 18x10 advan model t5 rims, hks front pipe, hks catback zorst, os giken triple plate clutch, 302rwkw, 100k service done
Good luck in finding one.
there's 3 1997 and 1998 MP1 R33 GTR's comin up at auction this week. All with xenons, one with heavy mods, one that looks buttfuck ugly and another that's bog stock.
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
