I suggest you take my Fairlane for a drive then lol.
drove my mums BMW 535i quite often lately and I like it.
Man, I must have getting older!
Any idea what is good replacement to 32r? Evo?
what do you mean by vobs spanned?
you choose the .IFO and it figures out the rest? ie VTS_blah.ifo which is part of 4xVOBS - is this not spanned?
if you want a pair of 650mb movies VCD style, then you choose 2 CDs (1400mb)
whats the issue? ... ?
it looks like a typical early 90s guy gets girl, two tough guys rock up, fight, random tities at the bar in a strip joint, fight, more fights, some cash, fight, end scene
no dodge viper
wrong movie..
dezz can you get cable where you are?
if you want shit fast and it to just work, bigpond cable is tops
i would never go back to anything else, i get staff discount so its a bit different but its tops
how much will tpg cost you
How much is cable? not sure if it's available at my new place..
got ADSL here through internode, bit of a rip at $69 or $79 a month for 40gb...Might sus out if TPG is available here, because if it uses the telstra exchange, that's just around the corner so should be fast...
If I can get it in my new place, it seems like the cheapest option for a decent amount of bandwidth... 60gb is $39 a month shaped to 256k/256k, doubt I'd use 60gb. or 200gb is $49 a month shaped to 1Mbps and there's no way I'd use 200gb
when was the last time you burnt a movie onto 2 x CD's?
useless file spanning i call it, given todays storage options
but if you want spanned movies, choose 2 CD's and away you go
what was the spanned vob issue?
Oh yeah, also, don't link directly to DVD decrypter on SAU, as it's an illegal piece of software (hence why the author of the program only posts the MD5 hash on the website so you can find it yourself.)
suck it up pincess, if you're gonna make a tutorial about how to make a scene release (like AXXO?), then at least stick to scene standards.
As for spanned VOBs, I was talking about something like son of rajab of the Rings, where the movie spans 2 DVD's, which you may wanna merge the VOBs from both main movies into one. Not the end of the world if you don't cover that tho.
scene standard this, i say 2x700mb is pointless and annoying
just means you have to rejoin it yourself after you download it
and the guide is for the average donkey wanting to rip movies
i spent ages stuffing around with xilisoft and it came out like ass most times
that guide helped me a lot so why not share the love
have you got a phone line there already (and do you need one?)
cos that adds to the cost as well, so you may find cable cheaper vs ADSL+phone line
There's a phone line here (parents house)
my place won't have one unless I put it in, wasn't planning to get a home phone as I don't need one, only reason I would is for internet...
http://www.tpg.com.au/products_services/adsl2plus_pricing.php?/pricing/homephone
Not sure if you need a phone line, thought that would be something you'd know more about than me?
There's ADSL2+ then there's 'naked adsl2+', not sure what the difference is?
From what I can see, if you bundle it with their phone line rental, which I guess I'd do considering I don't have an existing phone line, its $60 a month for unlimited... there'd be 3 of us living there so $20 a month each for unlimited net...how does that compare to cable prices?
had a quick look here - http://personal.optus.com.au/web/ocaportal.portal?_nfpb=true&_pageLabel=Template_woRHS&FP=/personal/bundles/broadbandhomephone&site=personal
if that's the right thing for me to be looking at, TPG would be cheaper for more bandwidth... Just have to hope it's available and at good speed
yeah naked adsl is dsl without a phone line
normal dsl you need phone line
bigpond is still a bit price exxy (pricks) 50GB for $79 without a phone line
nah when i said do you need a phone line, as in, do you want a home phone at your new house (a lot of people dont these days)
i didnt want one and i couldnt get naked dsl, exchange ports full so i went cable
yeah 60 a month is pretty good unlimited, hopefully one day bigpond will be competitive price wise
if you bundle bigpond cable with telsra phone line it might come out about the same ?
if you've already got a DVD and just want to copy it wouldn't you just pull a 4.3gb rip using DVDShrink, then burn it to DVDR rather than waste time converting to divx etc? DVDShrink plugs into Nero and ImgBurn etc so it's quite simple to pull a rip that way.
TPG changes your line over to its own DSLAM, so your telephone calls are actually sent through a transparent VOIP gateway. So you can't use it for faxes and for alarm systems etc. Easiest way to find out what arrangement they plan to put you on is to ask them if you can still send/recieve faxes on the line. It's a little shifty atm how they're sayin "$30 line rental" when you're in fact on a naked ADSL plan.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
