Hamish & Andy driving me home, any tips for steaming fish to keep it tasty without adding too much fat etc...
chinese style? there are many ways. depends on what fish too. freshwater fish require an extra step to make it palatable.
Not fussed on style, and won't be freshwater fish... Just been doing it in foil in the oven lately, can't be frying it in oil..
did i miss something?
why the hell is fuel 1.56 for premium
because of the embrago on libya
http://cgi.ebay.com.au/Nissan-Skyline-R32-GTS25-RB25DE-Manual-SWAP-/290539212792?pt=AU_Cars&hash=item43a57c8ff8
do motherf**king want, just sent a text asking if they want to trade lol
can't see him trading for an inferior model of the same car....
yeah its still a nice grab for 25k
assuming its not mangled or toast (could be given its been up for so long)
hamish
followed your instructions
good work bloke and came up pretty well for std porterhouse
any recommendations on good seasoning
but customer Is always right restaurants should keep that in mind
not even close to true. customer is very often wrong. the person that coined that phrase was a fkn moron.
there is no quicker way to get bad service than pulling out that line.
Just so y'all know. I'm buying a nice big juicy eye fillet on the bone. Hamish- how to make a nice red wine jus?
jus takes like 3 days moe.... how are you cooking it?
put it in a bamboo steamer baket over a wok, stuff it with herbs, lemon/lime etc :)
eat it with fish sauce, lime juice and chilli maybe? :)
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
    • So....knowing that I have a problem with power steering temps on track and another Wakefield day booked in next Friday, I've done the obvious thing They are very reasonably priced at $1650, considering they are a big monotube shock, double height adjustable (don't have to change pre-load to change ride height), one way adjustable damping and standard sized and customisable springs if you want something other than what comes with them. They come with 9kg/mm front and 4.5kg/mm front and I went with that as a starting point because I'll add adjustable sway bars too https://justjap.com/products/bc-racing-coilover-kit-ds-ds-infiniti-q50-v37-14-current#description Unfortunately they didn't come with rear strut tops so I've re-used the factory ones which was a bit of a pain. Also, the adjuster for the rear shock will be an absolute nightmare to get at, and while there are extensions in the kit I can't see any way you can actually attach or use them
    • I also had 2 bulbs blow at once, years ago in the stagea. made for a fun drive home. The issue was the voltage regulator had failed in the alternator and it was giving 15+ volts. Really, I was lucky all that was fried were the headlight bulbs. So, I'd suggest you check the voltage across your battery terminals with the car running and warmed up. Yes, you will need a multimeter to do so, sorry.
    • Good work to think to check that, and thanks for coming back to post up the outcome.
    • Given it happened suddenly, and when you come on boost, I'd check all your inlet - hose clamps in place and no split rubber or silicone hoses. Even the hard to get to ones near the intercooler. It's possible air that went past the air flow meter is being dumped out a big hole.
