they probably caught 1 guy 3k's over and had to drop it over radar inaccuracy...
not that the cops/media would ever blow hoon propaganda out of proportion of course
a HWP car went past in the other direction and would have radioed ahead for that guy to pull us over. They alleged that they had caught a few of us on their in-car radar thing, but obviously travelling in a pack they wouldn't have been able to determine who it was.
Is that Graeme off here? Gdogzgtr Graeme?
Never met Graeme but I highly doubt it, judging by the guy's attitude on the night.
lol @ facebook argument :D about which GTR is best to buy out of 32 33 and 34s
interesting discussion...
I often think to myself what I'd get if/when I get a GTR...
If I was to buy one right now, they'd all be an option...
all can look good if done right, and all can look pretty average if not done right...
hard to go past a 33 over a 32 if you're after bang for buck, as the price difference between them is pretty minimal...Newer engine/gearbox/everything else (barring rebuilds obviously). 34 is in a different league due to the price difference (mid 20's for 33, 40+ for 34)
those that are adamant about getting the 32, are usually that way because they see the 32 as the only true godzilla etc, or just love the 32 shape over the others...then there's those that can't afford either of the other 2...then there's those that can afford a 33, but dislike the shape and can't afford a 34...
Aus delivered 32 GTR is a collectible I believe...
Yeah I agree, but thats a little different there was only 100 of them made in saying that theyre still hard to sell at a premium price one has been on carsales for like 3 years now
imho, i think i will end up paying what ever they would be worth at the time.. i just HAVE to have an R32 GTR. something about them just makes me go all giddy, stock or modified. all the same
34r without thinking twice if money was no issue. Having said that i'd never pay 40+ for something with basically the same interior/exterior as a gtt. Bang for buck 33r wins hands down. I can't think of any reason why i'd get a 32r over a 33r. But that's just me
pretty much my thoughts...If money was no issue I'd have 1 of each all modified off their dick
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
    • So I found this: https://www.efihardware.com/temperature-sensor-voltage-calculator I didn't know what the pullup resistor is. So I thought if I used my table of known values I could estimate it by putting a value into the pullup resistor, and this should line up with the voltages I had measured. Eventually I got this table out of it by using 210ohms as the pullup resistor. 180C 0.232V - Predicted 175C 0.254V - Predicted 170C 0.278V - Predicted 165C 0.305V - Predicted 160C 0.336V - Predicted 155C 0.369V - Predicted 150C 0.407V - Predicted 145C 0.448V - Predicted 140C 0.494V - Predicted 135C 0.545V - Predicted 130C 0.603V - Predicted 125C 0.668V - Predicted 120C 0.740V - Predicted 115C 0.817V - Predicted 110C 0.914V - Predicted 105C 1.023V - Predicted 100C 1.15V 90C 1.42V - Predicted 85C 1.59V 80C 1.74V 75C 1.94V 70C 2.10V 65C 2.33V 60C 2.56V 58C 2.68V 57C 2.70V 56C 2.74V 55C 2.78V 54C 2.80V 50C 2.98V 49C 3.06V 47C 3.18V 45C 3.23V 43C 3.36V 40C 3.51V 37C 3.67V 35C 3.75V 30C 4.00V As before, the formula in HPTuners is here: https://www.hptuners.com/documentation/files/VCM-Scanner/Content/vcm_scanner/defining_a_transform.htm?Highlight=defining a transform Specifically: In my case I used 50C and 150C, given the sensor is supposedly for that. Input 1 = 2.98V Output 1 = 50C Input 2 = 0.407V Output 2 = 150C (0.407-2.98) / (150-50) -2.573/100 = -0.02573 2.98/-0.02573 + 47.045 = 50 So the corresponding formula should be: (Input / -0.02573) + 47.045 = Output.   If someone can confirm my math it'd be great. Supposedly you can pick any two pairs of the data to make this formula.
    • Well this shows me the fuel pump relay is inside the base of the drivers A Pillar, and goes into the main power wire, and it connects to the ignition. The alarm is.... in the base of the drivers A Pillar. The issue is that I'm not getting 12v to the pump at ignition which tells me that relay isn't being triggered. AVS told me the immobiliser should be open until the ignition is active. So once ignition is active, the immobiliser relay should be telling that fuel pump relay to close which completes the circuit. But I'm not getting voltage at the relay in the rear triggered by the ECU, which leaves me back at the same assumption that that relay was never connected into the immobiliser. This is what I'm trying to verify, that my assumption is the most likely scenario and I'll go back to the alarm tech yet again that he needs to fix his work.      Here is the alarms wiring diagram, so my assumption is IM3A, IM3B, or both, aren't connected or improper. But this is all sealed up, with black wiring, and loomed
