Prob bribed her with a wiggles DVD and some candy
LOL!
Only candy I bribed her with is my lollipop.
Lollipop - Lil Wayne. That shall be my song for tonight.
*Adds to seduction playlist on iTunes*
LOL @ recent topic of pedophilia and Jez working for Playspace.
Haha, yeah I've got a database in front of me with like 80,000 kindergartens, primary schools, childcare centres etc. :whistling:
I'll stick to 17+ thanks.
Btw, 17 year old girl is staying at mine tonight. So much win.
we should hang a bag of lollies off the back of your cars for the lulz
first time involved in an accident so im not sure what happens next...
got everyone's details, kunt at the back that started it agreed to fix all, he's insured with CGU. i don't have any insurance on mine. how do i go about claiming?
He has to call his insurance and get a claim numbers by giving him your information. He then calls you and gives you the claim number. You call his insurance. Give them the claim number and then they will organize repairs
Ah was gonna say if you had full comp you'd probably hope for a write off considering your selling...
Not sure how it works but woulda thought each driver is responsible for the car they hit, not the guy at the end responsible for all. Because if he hit you and pushed you into the car in front, he can argue that you weren't a safe distance from the car in front to begin with...
This is also true. So you got no insurance and the guy u hit is going to need money from you. Not the guy that started it. If te guy you hit has insurance they will be taking you to court over repairs as you don't have insurance
This is why I have full comp
dude infront of me barely had a scratch on his car/rear bar (which is queer since my front bar/cooler are pushed back) he said that he was gonna go after the guy at the end
Doesn't matter what he says man. He won't get anything from the guy in the back. Will sound stupid. But what they will say is that you did not leave enough room between you and the ar infront. You got lucky that it's only a scratch. Follow my first post to get your car fixed
Yip don't like your chances...It's all well and good for the guy at the back to say he's gonna pay for it all, but it's his insurance company that's gotta pay, and if they're not required by law to pay for the cars the rest of you hit, they won't.
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
