yeh ill happily take a refund on my membership and fk off this forum for good serisouly.
good example i <3 funky but goes around slammin everyone which is fine, since his a mod an all i call a bloke a pole smoker in an extremely warranted thread and get a warn?
...oh yeh.
dicktatorship much.
shame too there are some good dudes on here and heaps of people who would get more involved if it wasnt run so poorly.
nah i dont care but it still doesnt mean its not fkn bullshit, and IF your gonna have a set of rules in place then implement them properly.
fkn gimps shit me.
nah mohsen its the kents who are 'in' with the mods get away with anything everyone else gets to live in libya.
you keepin your gtr now man?
Yeah not worth selling it, mates decided to steer me away from evos, GTR will make some easy power once i throw a few k at it eventually turn it into a dedicated track car when it starts getting stupid on petrol and using for a daily.
yeh clean car anyway white is best colour :thumbsup:
Few problems underneath and hidden that I'm not to happy about but nothing to major.. will fix it all eventually - guess it is a 98 after all.
I want a black respray! use to have a white 33 N/A
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
