Clutch pedal squeaking like a bitch, how to fix?
Depends where squeaking is coming from. If footwell, spray some silicon near the top of the pedal arm and work it in by pushing the pedal.
If coming from outside the car, which is more common, spray some lithium grease on the clutch release fork/arm...the part of it inside the gearbox bellhousing, which rests against the pivot ball. You'll have to peel back or remove the rubber boot that the clutch arm travels through to get inside there.
i'll do that when i get my car back...
Cool thanks, too late to have a look now but it just started tonight. Wanted to make sure there wasn't any 'special' stuff apart from the usual... cheers
Oh and don't spray towards your clutch! Just focus on the pivot ball part and retaining clip, which is the cause of the squealing. It'll all make sense when you're looking at it.
off topic i found the best pho as well Ham
however you have to fly to vietnam lol
place called Pho 24 and it was awesome :D
lol i'm not surprised... :/
i work IN a pho joint now man, so i make my own ;)
Til his mummy makes him dessert. Thinking ahead. I like it.
For me, 12 hours til I eat something a bit more interesting :thumbsup:
seriously man, we dont need to hear about every chick you bone or think you are going to bone...
we've all had sex before (except mohsen)
    • Yes, I know🙄 but the sequential is not in my budget... don't want to reduce power neither, so looks like I'm stuck in the rabbit hole🤣
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
