You're assuming they'll sag without having seen them out of a top/bra...Shay Laren has her well and truly covered for size, and I wouldn't say they're hanging at her knees..
That and the fact the rest of her is amazing, there's no point wasting time talking about some other chicks cans you haven't seen..
Google'd - they are fatty/flabby rubbish cans that would be like playing with a balloon filled with milk.
Soft and squishy.
Try again.
Soft and squishy.
Try again.
That's up there with Jizzy boy's post as most ridiculous...
If you actually believe what you just wrote, you're a muppet, plain and simple.
Ash.
I'm also a fan of the smaller/firmer but I wouldn't knock back that chick, that's for sure!
Well of course you are. The ratio of 15yo chicks with big cans vs small cans is firmly in the small cans favour
:laugh:
:laugh:
Incorrect.
Have you seen 15 year olds thesedays?!! The younger girls I've been with have had the biggest cans lol. Always firm though ;) Wouldn't wanna see them in 30 years..
Soft and squishy.
Try again.
Whats wrong with big tits?
So they might be a bit lower, but thats gravity!
Small girls with big cans ftw, you guys are forgetting about ass, can always play a big part.
On the boob topic, depends on the girl, some look hawt with hooters while some can get away with little tits, me personally. I like a decent sized set.
Bit early? :P I pretty much don't sleep lol.
I agree, in that pic it looks that way, but in the movie you'll see it's not the case :) She's also a bit flatter than that I think.
Birds, do you still have plans for tonight? Gathering at mine if you're keen (same goes to anyone else, except mohsen)
Forever alone.
All I'm going to do this long weekend is SLEEP.
Edited by Mohsen
Having a GF with the largest set of breasts I've had the pleasure of working with, I can say I'm amply qualified to have the final word on mamories of such magnitude.
1. They sit well naturally
2. No strech marks, yet...
3. I'm sure with age, there will be some issues
So the verdict, enjoy thenm young. Them lop them :D
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
