Hey guys, my mate gave me a lil led display that you wire up as an air/fuel ratio display....
The wires are:
positive, negative and O2 sensor.... Ok, so the first 2 are a piece of piss....
actually, should i wire the positive throu accessories (cigi-lighter cable) or straight to battery? or other?....
now, the question i an totally stuffed on.... the O2 wire.... where and how???
all help appreciated... diagrams are excellent....
cheers.
Dave.
https://www.sau.com.au/forums/topic/31123-wiring-up-air-fuel-ratio-leds/
From memory, you need to tap into the white wire off the O2 sensor. Check it with a multimeter - output should vary between 0 - 1V.
Hook the power off the ON posi - ie only supply power while the engine is running.
Ok, i know the sensor your talking about now.... might be fun to get to... lol....
blind_elk: when you say to hook the power off the On posi (i'm guessing the ignition switch)... how do i get in there (neva been there on this car)... just take the steering casing off? which wire? (colours etc)...
thanks again.
Just need to find something that only works while the engine is running - maybe something like the wipers (I can't remember how I did mine).
It's not so hard to splice into the wire at the sensor, but you could alternatively pick up pin 29 at the ECU.
Ok, so i'm guessing i'll be taking out the floor in the passenger foot well and looking for that wire then?...
then what would you suggest i spliced the +ve wire into? If i connect it to the ciggi lighter will it work without a switch?.... I've only ever hooked the neons up through that wire.....
