hi all
Im trying to find out how much boost a stock rb26 can hold to stay relatively safe i was planing on a full forged high boost rebuild but have just found out ive got a baby on the way :( so dats been put on hold but ide like to up the boost a little bit as its only running the stock 7 psi. Also ive got an apexi avc-r boost controler in the car dat the car was imported with what would be a good range for the high and low etc.
any help would be great thanks.
https://www.sau.com.au/forums/topic/311349-rb26det-how-much-boost/
the ceramic turbine wheels are fairly well known to die if pushed beyond 15psi
you can get 260rwkW out of stock turbos with a full exhaust upgrade and a programmable ecu, which pretty much matches the safe duty-cycle limit of the stock injectors anyway
thanks mate
as my stagea is the rs260 ive been told that its the same running gear as the gtr with steel turbin wheels i havent pulled the intake off to make certain if this is true but how much of a differance would this make could i go higher later down the track if i upgraded the exhaust and injectors etc...... thanks again......
Don't run the standard turbos at 20psi. They are the same as the R34's which have ceramic wheels.
http://www.skylinesaustralia.com/forums/R3...eel+wheel+turbo
Correct
Some may last a while at that level but that won't be the norm.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
