you mentioned other GTR bits: shoot me your number I have to make a run up there anyway so I can pop past and see you.
  • Replies 73
gearbox still available?
I'm chasing a 32 or 33 gtr box, for 6 speed conversion into my gtst.
yes i know what to do to convert to gtr box lol
if you're selling it how much? PM me
I'm located in Toowoomba as well so I imagine you'd be close to where I am.
Cheers
Edited by fattox33
Cheers
only the 34 had a 6 speed box!
issues like what?? it all depends what you are capable of as to what constitutes it bieng an issue i guess... for me doing it there are no issues as the rb26 also came in r34 gtr's
main issue would be wiring but i know a guy who can do that quite easilly for a good price and the sump which you can buy off the shelf from high energy now i believe
here are some pics of the turbos...
the compressor wheel size with the vernias seems to be around 47mm but hard to say exactly on such a weird angle
a guy from MTQ turbos came and looked at them on the engine and said they are definatly not factory nissan turbos and they appear to be ball bearing also
factory compressor cover is .42 but these are .6 and seem reasonably large by comparison
also included to pics of the std ones to compare
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
