  • Replies 50
I don't understand (then again I don't have an iphone lol).
Can't you browse web pages from an iphone? I though pretty much any high end phone can do that?
My phone can browse SAU... and i don't need to pay for any App...
you can use it fine and i do all the time; loads the page just like normal, but you have to zoom in and out on the screen to click on links and read things comfortably. you can select the 'PDA skin' from the board settings, but it's still not optimal
a proper iPhone web-app would have a set-up that scaled and spaced everything to suit a small screen, like the one for Facebook, f'rinstance.
https://www.sau.com.au/forums/topic/311768-iphone-app/#findComment-5131453
Now posting through my motorolla milestone phone via wifi doesn't take too long to load pages at about 5-6 seconds max (main page) 2-3 secs for each topic but would be nicer to have a mobile version of the site enabling to load pages instantly without the need of double tapping on screen to zoom.
Although I sympathise with iphone users with their smaller screens and some what slower web browsing capabilities :ermm::)
Edit: just discovered that I need to login every time I want to post. Don't know if its just. My fone or the site?
Edited by Barbarian
https://www.sau.com.au/forums/topic/311768-iphone-app/#findComment-5145886
http://www.tapatalk.com/
This is an app you can use but the forum needs to get it happening on their end first.
might be an option?
IPB support was supposed to be out last month.
That looks really good. Still no IPB support by the looks, but I'll check it out in more detail.
https://www.sau.com.au/forums/topic/311768-iphone-app/#findComment-5147369
I'm working on a theme (like dark and light that we use) that is iPhone friendly, then its just a matter of detecting useragent and overriding the theme.
although, I'm only like 10% done with it, given the complexity of the forum.
https://www.sau.com.au/forums/topic/311768-iphone-app/#findComment-5147625
We've just integrated Tapatalk into one of our forums here :
http://www.sensational-adelaide.com/index....s&Itemid=13
Dead easy to setup, took around 10 minutes, didn't have to change too much to the website layout it was just one line at the bottom of the footer.
https://www.sau.com.au/forums/topic/311768-iphone-app/#findComment-5160826
    • I myself AM TOTALLY UNPREPARED TO BELIEVE that the load is higher on the track than on the dyno. If it is not happening on the dyno, I cannot see it happening on the track. The difference you are seeing is because it is hot on the track, and I am pretty sure your tuner is not belting the crap out of it on teh dyno when it starts to get hot. The only way that being hot on the track can lead to real ping, that I can think of, is if you are getting more oil (from mist in the inlet tract, or going up past the oil control rings) reducing the effective octane rating of the fuel and causing ping that way. Yeah, nah. Look at this graph which I will helpfully show you zoomed back in. As an engineer, I look at the difference in viscocity at (in your case, 125°C) and say "they're all the same number". Even though those lines are not completely collapsed down onto each other, the oil grades you are talking about (40, 50 and 60) are teh top three lines (150, 220 and 320) and as far as I am concerned, there is not enough difference between them at that temperature to be meaningful. The viscosity of 60 at 125°C is teh same as 40 at 100°C. You should not operate it under high load at high temperature. That is purely because the only way they can achieve their emissions numbers is with thin-arse oil in it, so they have to tell you to put thin oil in it for the street. They know that no-one can drive the car & engine hard enough on the street to reach the operating regime that demands the actual correct oil that the engine needs on the track. And so they tell you to put that oil in for the track. Find a way to get more air into it, or, more likely, out of it. Or add a water spray for when it's hot. Or something.   As to the leak --- a small leak that cannot cause near catastrophic volume loss in a few seconds cannot cause a low pressure condition in the engine. If the leak is large enough to drop oil pressure, then you will only get one or two shots at it before the sump is drained.
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
