Easternats Cancelled.............again
  • Replies 237
Posted Images
WRONG!
1 - Driving fast on a track and driving like a f**ken retard on the roads are two different things. Not every owner of a fast car likes to act like a spanner.
2 - Protesting is one thing but there is a right and wrong way of doing things. It's as simple as that, this is high school mentality...
1) if your telling me you never planted your foot whilst having your skyline on the street you would no doubt be lying. Also your talking about tracks. This event was meant to be on a track. Take that away and of course there will be tools going nuts on the streets. After all this time we don't have a drag strip in s/se Melbourne. I can see a SHITLOAD of cars going if that existed instead of usin the highway as one
2) totally agree
I've given it a good flogging on the streets, to a certain extent. Problem is some people just don't know the limit or when enough is enough yeah. It's not right and yes I broke the law but you need to at least have the decency to pick a time and place. Hey if ended up into a tree hurting no one that my problem huh :banana:
You're right in saying "tools". I don't think any sensible/rational persons thinks "oh the events been cancelled I'll go an race on the roads". If you street race you do it because you love it, you don't need an excuse.
I've given it a good flogging on the streets, to a certain extent. Problem is some people just don't know the limit or when enough is enough yeah. It's not right and yes I broke the law but you need to at least have the decency to pick a time and place. Hey if ended up into a tree hurting no one that my problem huh :thumbsup:
Yea of course we all let loose a little bit within reason. I'm sure most of us don't go 180 on princes hwy swirving between traffic but there are idiots that do and have no respect for anyone else on the roads And their lives. Also I think the cancellation was just an excuse to act inappropriatly. Guess they are facing what's going to happen to them. My guess is a fine and community service or a suspended jail sentence. They will get off easy
Coming from the guy that was not all that long ago bragging about being done in a 60 zone, claiming to be doing ~200km/h (which is bullshit anyway, the fact you claimed it just made you more of a tool)...
dezzownd.
Hmm how many years ago was dezz? Hmmm I don't give a shit. Was a straight 3km rd at 4am. Big deal. + I think you already got the idea that I don't give a shit what you post here as do many many other people haha so shove what you think up your ass :)
Oh no, the internet doesn't value my opinion....
Don't flatter yourself, I couldn't care less about your opinion if I tried.
Hmm how many years ago was dezz? Hmmm I don't give a shit. Was a straight 3km rd at 4am. Big deal. + I think you already got the idea that I don't give a shit what you post here as do many many other people haha so shove what you think up your ass :laugh:
So it was within reason... Yeah...
:thumbsup:
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
