car is a 34 gtt auto
only got basic mods:
3" turbo back/split dump
front mount cooler
12psi
gtr bov
recently ditched the pod for factory airbox but still using steel intake pipe
should mention that budget is tight so no big $$$ power fc's and such :D for now anyway...
my target is around the 220rwkw mark
cheers
https://www.sau.com.au/forums/topic/312456-need-guidance-re-next-mod/
check what diff gears you have - auto's usually run different vs manual, manual will give you more lateral acceralation
safc is a must for auto as you can't change ecu and are cost limited
dont run mega big wheels sub 19s, smaller will give you better acceleration
go for the SAFC and tune the pants off it
it will make a big difference to how the car drives
+1 for nistune!! cost me $800 for a type 4 board installed with a tune. very happy and its now there for when I hiflow the turbo.
plus it is all internal to the ecu so no hassle from the cops!
Edited by Harey
My advice to you is to check that eveything else on the car is right before you go modifying anything else:
Brakes
Susp/Bushings
Belts, plugs and consumables
Lights
Saftey equipment.
Then if you still have budget leftover, look into highflowing your turbo or installing a nistune board.
Brakes
Susp/Bushings
Lights
Saftey equipment.
Bah! boring,
Strap on a T88, up the boost and hold the funk on! YAGRHOOOOOOOOOOOOOOOOO
id be going the nistune route mate.... safc arent that much cheaper and you got to get it instlled and tuned anyway.....also upgrade the fuel pump... i would also consider getting a shift kit stage 2 in the auto get the lazy auto box shifting gears more firmer.....
  R-SPEC said:
i think i'll settle for a SAFC and tune for now
thanks for your help fellas :blink:
You will regret it, absolute waste of money, your next mod after that will still have to be an ecu upgrade, save some more and go the nistune, atleast with a nistune unless you are aiming for over 400rwkw you will not need to upgrade it for future mods.
Brakes
Susp/Bushings
Lights
Saftey equipment.
+11ty
    • Hi ๐Ÿ™‹โ€โ™‚๏ธ. Just bought my Unicorn but the interior need some minor work so it would match my expectations ;). I noticed it is hard to get used oem floor mats in good condition so i started to dig if there's any chance to buy set of new ones. I found two websites - nengun and amayama and it looks like one can still buy factory new floor mats in Japan, but thers a small issue. Some mats (i assume genuine, oem ones) are marked as G4900 and these are "discontinued". The ones you can buy are marked as G4911 but i have no idea if these are also oem, made by other producer or some lower quality replacements that looks entirely different. Can anyone help? ๐Ÿ˜ƒ  P.s. there is also some strange indication - 0V005, 0V015 and 0V505. Any idea what does it mean? Would appreciate any help with this ๐Ÿ™
    • Hi, Marek here ๐Ÿ™‹โ€โ™‚๏ธ. I finally fulfilled my longtime dream - recently bought Stagea and now waiting for it to arrive in Poland. There's only few of these in my country, and one of the owners  recommended mi this forum as a source of all the info i'd need since now i own one  so here i am.
    • Version 1 aluminium airbox is.......not acceptable No pics as I "didn't like the look.....alot" Even after all my "CAD", and measurements, the leg near the fusebox just didn't sit right as it ended up about 10mm long and made the angle of the dangle look wrong, the height was a little short as well, meh, I wasn't that confident that Version 1 was going to be an instant winner I might give Version 2 another go, there's plenty of aluminium at work, but, after having in on and off a few times, and laying in the old OEM airbox without the new pod filter and MAF, there may be an option to modify the OEM air box and still use the Autoexe front cover and filter.... maybe This >  Needs to fit in here, but using the panel, and not the pod, the MAF will need to fit in the airbox though> I'm thinking as the old OEM box and Autoexe cover that is sitting in the shed is just sitting around doing nothing, and they are relatively abundant and cheap to replace if I mess it up and need another, it may well fit with some modifications to how the Autoexe brackets mounts to the rad support, and some dremiling to move it get in there, should give me some more room for activities, as I don't want to move the MAF and affect the tune Sealing the hole it requires to stick it in the air box is simple, a tight fit and some pinch weld will seal it up tight  I am calling this a later problem though
    • and it ends up being already priced in as though you're just on 91RON without any ethanol. Car will lose a bit of economy as the short and long term fuel trims bring down the AFR back to stoich or whatever it is for cruise/idle for the engine.
    • Oh, you are right. But, in Australia E10 is based on 91RON fuel and ends up being 94RON. Hence it being the cheaper option for economy cars. The more performance oriented cars go for the 98RON fuel that has no ethanol mixed in. The only step up we have left then at some petrol stations is E85.
ร—
ร—
