Hi guys i have a question about removing the 'Nissan' and 'GTS-T' off the back of my R32 but they arent badges they are just like a sticker. I know there are other topics about removing adhesive badges etc but not sure about this. Pics are there feel free to redirect me to another topic.
Cheers
BG
https://www.sau.com.au/forums/topic/312602-removing-whats-left-of-badges/
Hair dryers will heat the plastic and soften the glue, should just peel off, then just clean with tar and grease remover or prepsol.
He was talking bout the stickers at the rear
anyway I used methylated spirit to remove mine,
if that doesn't work then turpentine will do the trick
  • 2 months later...
MLR is correct. Hair dryer to warm it up and then use your fingernails to take them off. It really is the same method as taking any sticker/badge off of the car. Be warned though, the paint underneath the sticker may be a different shade than the rest of the car and will stand out, especially if your cars paint is pretty old and sun damaged.
Edited by PM-R33
a good cut and polish should fix that right up
yes in some cases, but most skylines have old paint and you can only cut and polish it out so much. Most times you need to paint.
its true
my car was debadged completely when i got it sprayed.
much better imo
    • Neg, the top one is actually for the front. The sizes are 18x10.5 +18 and 18x11 +32.   I measured many times but I'm sure I'll have problems as this is the thread for problems.
    • Just one thing; tapping tapered threads is tricky. Taps are always tapered and you would generally run it as far as you can, but with a tapered thread you have to stop much sooner otherwise the wide part of the taper will run in too far and you will have to thread the sensor in too far too as well (possible that it will never make a good seal) BTW nice wide wheels, I guess the top one is for the back!
    • Welp, good to know. Will have to wait awhile until steady hands with drills and taps are available. In other news, these just arrived! I will weigh them for posterity. Edit: 11kg each (or 10.9/11.1 depending on what my scale decides over multiple tests, the 18x11 don't seem to weigh noticeably any more than 10.5)
