  • Replies 48
this is my new fule set up in my r32 gtr
consists of a think a Holley lift pump drawing from a custom 43lt Alie tank filled with fuel foam,
running to a fuel regulator then to the swirl tank then to a bosh 040 external pump and then through a cleanable fuel filter then up to the front,
the in the engine bay to a turbo smart reg and then to the rail
Here is my setup I have been making, not quite up to the flow you guys are probably after for E85, but should be good enough to give me a simple, light, cheap and reliable supply for my track 180...on PULP.
http://www.skylinesaustralia.com/forums/Pu...-C-t316767.html
It will be interesting to see how you go Scott. From what I'm told, and it makes sense to me, is that the standard fuel tank is a benefit for our cars in terms of weight placement (lower CoG), weight transfer on power down, and airflow under the car (not an issue with a flat floor if that's what you're planning). It was for these reasons that I decided to stick with the standard tank and go this setup:
Unknown in tank fuel pump
Bosch 044 external fuel pump
Autobahn888 Surge tank
Custom enclosure
Sard Fuel Pressure Regulator AN#6 fittings
Custom CPC Fuel Rail
Sard 800cc Injectors
2 x Fuel filters
    • Kinda glad I never got to this ..    https://www.facebook.com/groups/1483859159195077
    • @GTSBoy This method was able to get readings of -10 to -2, so it looks like its monitoring.  Now I need to figure out why the vacuum on the line provided isn't alternating with manifold pressure.  I went with 2 lines that an RB25 tuner recommended but I'll get a longer hose and try directly off the back of the manifold.  He may have been used to OEM intake setups while I have a DBW setup that removed the MAF and IACV.
    • I work at a car detailing and tinting shop called Quark which gets all manner of German cars in usually (mainly due to a contract with Mercedes Benz Kita Osaka, BMW Nishinomiya and others) but every once in a while something special comes in, like a fully restored 1972 HS30 Nissan Fairlady 240ZG... The shop owner had immediately started applying film to the windows as soon as it was in the shop so the interior was completely covered in towels and plastic sheets. But I could get a few photos of the engine bay which was restored like new. Such an amazing car to see in pristine condition in Japan these days.
    • Was going to say the car pulls up nicely everywhere, especially going into that last long right hander before the main straight. Looks like a lot of fun.
    • Hey Dave, welcome aboard! Good to see another soon-to-be Stagea owner here. The wagons are awesome — plenty of space, still got that Skyline DNA, and loads of potential if you’re into mods. Definitely post up pics when you get it, everyone here loves seeing new builds. What model/year are you looking at?
