Well done Fatz.
The Fosters we (you) had this afternoon is not beer.
Love the excuse and I do agree that the water will dilute your carbs.... Always here to help, see you tomorrow............... Now I Know of your diet, I think your the driver or is it NY Tea.
  • Replies 80
Good on ya Pete ;)
Reckon red wine would have to be a winner :(
Hey Nads - thinz reckons you don't let up till you have put away 10 scoops a day, how come you arn't stacking it on - or are you?
Have to meet up for a beer soon guys - haven' had one with ya this year!! :cheers::cheers::cheers:
c how we go having a curry for lunch... just the curry
should be good
bonkers... had a bottle of read last night, gonads had a bottle of white 3 beers
i think we should have an official "get blind drunk" at bonkers house one day sau day
im there
I'm with Roy on everything he said.
Whilst losing weight, it is almost impossible to maintain muscle mass. Even if you continue to hit the weights regularly (4-5 times a week), you are still at a calorie deficient state, so your energy has to come from somewhere, and unfortunately it doesn't all come from your fat stores hs.gif
Simply, to lose weight, it's as easy as having a lower caloric intake than you're expending. That is, you need to eat less calories than you're burning. It's simple science. No matter what you eat, if you are caloric deficient, you will lose weight. What you eat whilst doing this dictates WHAT you lose though (fat, muscle, water, etc), so it's not good just to eat 2000 calories worth of beer a day ;)
For a steady and healthy weight loss progress, aim to eat about 500 calories less than what you're burning. If you do lots of cardio (a 10km run burns a LOT of calories), you can eat more to compensate. Any less than a 500 calorie deficit and you'll notice too large a drop in energy and more likely to feel hungry and binge eat (drink beer)
Also, I don't think you'll enter a state of ketosis with an intake of 30g of carbs a day. I would think a figure of 5-10g would be more accurate.
Good luck Pete!
No one has tried this as a serious scientific method of losing weight, but if you become an alcho and get liver damage and a host of other physical probs then im sure you could drop massive amounts of weight.
You can use "Leaving Las Vegas" as inspiration or a training video, forget dieting, this regime is the ultimate in commitment ;)
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
