my best 60' was 1.55s & 129.75mph
i was also running drag radials which made my 60' :(
tyres were compliments of paul & his mates dog (dave) was eyeing out my nads when i returned them lol
i still blame paul for not cracking a high 10 - he told me to hold in 3rd gear across the line...i was on the limiter for almost 1 sec on my good run (paul u baaaad)
  • Replies 186
steve - what back2back tests u doing with yavus, stock v's match ported manifolds?
did u end up going bigger with your exhaust system as well?
Nah no that sort of thing, Pauls referring to his car vs mine as we have a lot of the same parts
Yep the exhaust is going to be a massive step up from the crappy peashooter on there now. I'll get pics up asap for you guys. The best bit? It's specific to rb30 gtr's so no spacers needed :(
and so are uncovered air filters, wheels that are larger than 17inch diameter on an r32 etc etc etc
Check the wheel rules mate, unless they've changed lately you can go bigger than 17's on R32 (vspec2 had 17x9's stock). From memory the rule is 2" up and 1" wider than stock fitment
The uncovered filter rule is pointless with EFI cars. Keep up the good work RTA.
<snip>
Im in for a joint booting from WSID. We can go one after the other in one lane just to make a joke about it. Do you think they'd kick us for slamming the brakes before the finish line?
You could do things a few ways to avoid being booted:
Firstly, you could launch full-steam and back off after half track so that you don't go under 11's. This will give you a decent 60' time and also half-track time and MPH.
Secondly, you could break the beam on the green by creeping forward to trip the start timer...then launch the car and go as hard as you like. This will add to the ET but will give you the correct MPH.
You could then get an estimate of the car's potential by adding the best of both types of runs to see what the car is capable of.
Thirdly, go out for the final run and do a full pass and get booted :D
Then you could go back a couple of months later with different plates and do it all again >_<:D:D
Ideally, you could do this at a private day such as this one:
http://www.skylinesaustralia.com/forums/Ws...ay-t331950.html
and get PLENTY of practice runs in before doing a full pass at the end of the day (or when you get bored) and get the boot >_<
Lol, endurance racing much? That's a shitload of fuel
Or just enough to get you to the shops and back on E85... >_<
Also the wheel rules are so farking weird.
Secondly, the surge tank in boot isn't illegal if it is covered and vented properly. (It really should be setup on a charcoal canister like the tank).
This is the same for the battery, if you don't have a sealed battery it is meant to be enclosed and vented outside of the car (For R33s etc)
Yeah smart move. The 1000's just wont do the job
Why are your drags closing? Is there a racetrack where the straight can be used instead? Eastern Creek used to do that up here. Anyway, you get Targa roads, thats more than enough :)
Tarmak has been having trouble for ages. Now they cant form a commitee and doesnt seem like they have the money to keep it running. The track needs lots of attention and last time I raced, after finishing the 1/4 the run off turned to shit and there was pot holes and weeds growing everywhere.
There are 2 tracks in Tassie, Symmons Plains up north and Baskerville down south. But dont think the straight would be long enough.
Or just enough to get you to the shops and back on E85... :)
Hahaha yeah...with e85 on the cards she will chew a bit...somthing along the lines of 90-100L an hour at full noise
i think the bugatti veyron goes thru a full tank of fuel in something like 9min @ full revs on the autobarn :)
    • If you mean the alarm immobiliser; theyre internal to the alarm itself which makes that difficult; I couldnt even see where he put it; its not in the same place as last time; but with all black wiring it might be very challenging to trace  I had someone turn the key for me as I know it only primes for a couple of seconds As my post above; I am getting no voltage to the pump at all; but I am testing continuity of the power line (SB) from the pump plug to the relay fine. As well as the negative from the pump plug to a 12V constant.    Yeah; he blammed the no start on a bad battery; said I needed to get a new battery and it'll start. Turns out the battery drained because the tail lights had been on for half the day during the install (the rubber cushion on the brake switch gave out while he was testing it as I have a picture of the car from that morning with the tail lights off..i've replaced that). The battery was turning over the engine just fine for a long time; but got low since lights were draining it so it was too low to test a start after he finished. I bought a new one on his advice...$250 wasted. My original battery charged up just fine and is healthy.    It was running perfectly fine when I messed up the old alarm (programmed out the remotes). He couldnt start it after removing the old alarm; my assumption is that when he unhooked it; he didnt bridge the circuit back when trying to start it. Its always been perfectly fine. The ECU swap and pump were 2 years ago. It's never missed a beat in that time.
    • This is a big issue for me without the diff. I just have zero drive from the passenger side when drivers side has no traction. Bec's parents place has a crazy steep driveway with odd camber and I have never been able to get up. My bro-in-law's 130i with an (unknown brand) LSD gets up fine as does their dad's Hiace. My car stays at the bottom. We have other odd camber roads around here as we're elevated a bit and if it's raining I can get totally stuck around some hairpins.
    • Yeah, I am super excited for this.
    • Was the car running before he touched the car?
