this makes me wanna take the rear badges off.
does anyone know if there are holes behind the nissan badge?
There are not, it is just that double sided tape/glue stuff that holds them on.
By the way, did you notice the "TEPS inside" stocker on the rear window of that CE28 equipped M35 above?
If you wanna see what they do with M35's, click on my sig.
Since this is the 5th M35 I have seen with this sticker akes you wonder why they didn't want to do the intakes when they had the chance, aye Craig?
Thanks! Just spent 2 hours trying to find some online... anyone know where I could source these from?
Chris.
You may be searching and waiting for some time Chris.
The Dayz M35 only ran in the series 1 model and was very, very limited at that.
Perhaps if you are after something similar, you could go after a Kenstyle PM35 half rear bumper
If you are having trouble finding it, shoot either Import Monster or Jesse Streeter an email with the link to the page requesting a price.
I am sure they would both be more than willing to help.
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
