this makes me wanna take the rear badges off.
does anyone know if there are holes behind the nissan badge?
There are not, it is just that double sided tape/glue stuff that holds them on.
By the way, did you notice the "TEPS inside" stocker on the rear window of that CE28 equipped M35 above?
If you wanna see what they do with M35's, click on my sig.
Since this is the 5th M35 I have seen with this sticker akes you wonder why they didn't want to do the intakes when they had the chance, aye Craig?
Thanks! Just spent 2 hours trying to find some online... anyone know where I could source these from?
Chris.
You may be searching and waiting for some time Chris.
The Dayz M35 only ran in the series 1 model and was very, very limited at that.
Perhaps if you are after something similar, you could go after a Kenstyle PM35 half rear bumper
If you are having trouble finding it, shoot either Import Monster or Jesse Streeter an email with the link to the page requesting a price.
I am sure they would both be more than willing to help.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
