I have with the HKS cast manifold which has the wastegate sitting right on top. The very short run to the gate is the worst it can be if you want to keep both sides divorced. I am guessing there wouldn't be much in it once gasses start moving at any speed.
Is that stainless ?? can't wait to get my stainless mani in favour of mild steel.... might be alright if it doesn't get too hot.
had heaps of issues with turbo to mani gaskets etc, and Grant at Per4manz turbos is pointing the finger at the stainless and turbo rear having different expansion rates...stainless is something like 10mm per 1m.
you might not be putting as much heat as the TO4 at near on 2bar, so might not have any issues...just saying (-:
I think so, but looks identical to that one. no cracks or anything, just trouble mantaining a good seal between turbo and mani, Grant thinks due to stainless flange against cast mild?? , had them both faced a couple of times, tried every type of gasket. The permeflex ( or whatever its call ) 5 layer one thats on know seems to be holding up, but hasn't seen too many long track sessions yet.. next time it lets go, its a 6-boob steam pipe or similar.
Pffft PJ. Joels is slowly catching up. U too should race :) rules are no higher than 6000rpm hahaha
Just got his off the dyno, full boost 24psi @ 4300rpm revving to 7500 335kw
Will push for more boost soon. Had to take it for a run
E-Flex, that's E85 yeah?
Top end power is great but a little laggy? I'm reading 15psi@4250rpm, 20psi@4500 and 24psi at 5100rpm (all approx). Do you think these can be improved upon with better boost control? What size gate is on there now?
I've got a 5858 and was hoping for better response that that but not so sure now!!
Don't forget it's a 2L SR20 not a RB25
It's making at around 4300rpm which I wouldn't have thought is too bad at all
Yes understand its a SR20 which is what I have.
The top end is sensational and a great result. Don't get me wrong, not meaning to be critical but would have hoped for more action a bit earlier.
In any case a dyno doesn't tell you how a car feels on the road.
Like I said I have a 5858 that is going onto a 2L (maybe a 2.2L) so am really interested in the response and power of these things. The slightly larger turbo should be able to make 350rwk or so. I guess I will find out later on.
I dont think the lag is as bad as it looks. You cant expect too much response from a 2L with a 300+kw turbo man.. For me its really on par and I think its a good result.
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
