Opinions on a 6466 w/ .84 TS on a built 2.6 with 272/272 10.2mm lift cams?
I have poured through this thread, and as such was leaning towards the 6262 or even considered the 6062 Gen2 thats just been released - but my engine builder is telling me the 6466 is 100% the go
I trust the workshop, but just want to double check other's results; dont want something that comes on at 5k or later.. id rather it come on hard at 4.2-4.5k rpm
Its concerning seeing people say a 6466 outflows a T51R
A rb30 usually adds about 500rpm response all things equal... My cams are bigger than yours, so you could possibly base it off that. I'm using a 1.0 divided housing.
I don't think it will be bad, certainly better than a T51R in response, even if it does flow more top end. Thats the beauty of new technology.
If you're worried about response though your are probably better off with a smaller turbo, unless you have a power figure you definitely want. Take into account the 6466 is a 600awkw turbo
Depends on car use, I'd be giving a 6062 a go if your stuck between the 6262 and 6466 for a decision. It should sit right in the middle in response and power :)
I try and do everything with my car from tight sprints, circuit work,1000m drags and powercruise etc. and the 6262 is right in the sweet spot of power and response. I actually turn it down 140hp for everything apart from powercruise and drags because it's more than enough. What do you want from your car?
A 6466 is going to be responsive for its size but it's getting towards drag car only power band on a 2.6L, if that's what you want then go for it but your never going to keep up with the Jones's.
What would you guys recommend for. Street drag VL, auto re401a
Forged Rb30 NEO head
270 9.2mm cams
Plenum etc etc 3k stall
Currently running gt35 .82 internal gate
22psi 422hp but out of injectors
98ron
I was looking at the 6466
6466 1.0 divided.
I make 433awkw on 22psi, 98
100kw more on e85
Should be plenty to run 9's
It's been a while but here is my Dyno sheet from build
Rb26 precision 6262 at 19 psi.
Car is running good other than its smoking from turbo.
Anybody here using restrictors? I just put a .030 restrictor and stopped smoking but not sure if I should drive it.(n1 pump)
EC990DBB-75E3-4453-89C1-EC9B0C5E4339_zps
Thanks for the quick reply guys. Haven't removed the factory restrictor. I'm running a -4an feed line and a -10 am drain line. Drain line is pretty straight down with now kinks. I also did a leak down test and compression test on the engine. Got 128 psi on all 6 cyl.(running 8:3:1 CR) and dry leak down test was 10% on al 6 but #1 13%. Not sure what other options I have
I'm getting 45psi. Pressure at 2.5-3krpms and over 60 psi from 4k up
Edited by silvianc
Is that America?
because that is epic power in Australia for that boost
Lol yeah. I'm in the U.S.
Setup made
390hp@9psi
450@11psi
560@15psi
611@19psi
This is on a 2.6, 87mm pistons and Tomei type B cams, t4 .84 divided housing and limiter on 8400 Rpms but u can see dyno sheet actually was 7.8k Rpms
https://m.facebook.com/story.php?story_fbid=773329676088103&id=142284982525912&_rdr
Our horses are angrier
Hell yeah. I'm in the USA too. Here I am thinking of seeing 550 whp on pumpgas and I'm at sea level and I'm on a stroker motor. Heck I may see 650 whp on pump after seeing this !
You'll probably see 550 Australian horses if you've been looking at our graphs. More if in USA
    • If it dies, then bypass. The task isn't difficult. I have one running on a standard R32 FPCM. That's after nearly 20 years of it running an 040, which pull substantially more current than the Walbro. They're not the same module, but I'd hope it indicates that the R33 one should be man enough for the job. I think people kill them when putting proper sized pumps on them, not these little toy pumps we're talking about here.
    • Silicone spray won't hurt anything. And if it does, that's an opportunity to put some solid steel spherical bushings in, so you can really learn what suspension noise sounds like, If you're going to try it, just spray one bush at a time, so you can work out which one is actually noisy. My best guess is that if the noise started only since putting the coilovers in, then it is just noise being transmitted up through the top mounts of the struts, and not necessarily "new" noise from bushes. But it's almost impossible to know.
    • Are you saying the 34 is SUV height, and not that we're talking about an SUV here? (because if we're talking about an SUV, you don't fix them. You just replace them when something breaks. Not worth establishing sufficient emotional connection with an SUV to warrant doing any work on one). I wouldn't jack my car up on a short little loop of 10mm steel rod poking out through a hole in the bumper bar, front or rear end. I realise that we're probably not talking about that type of loop at the front, being the one under/behind the bar on a Skyline.... but even for that one, trying to jack up on what amounts to a thin piece of steel, designed purely for withstanding a horizontal tension force, not a vertical compressive force (and so would be prone to buckling/crushing) and, my most particular bitch about it - located RIGHT AT THE EXTREME FRONT OF THE CAR, applying a load up through the radiator support panel, etc, with almost the entire mass of the car cantilevered between there and the rear wheels? Nope. Not doing that. Not on the regular. That structure out there in front of the front crossmember is not designed to carry load in the vertical direction. Not really designed to carry any load at all, really. The chassis rail that the tow point is connected to would be fine loaded in tension, as per towing. Not intended to carry the mass of the whole car, especially loaded all on one rail, with twisting and all sorts of shitty load distribution going on. No, I will happily drive up on some pieces of wood, thanks. That can only happen on driven wheels, and they are at the other end of the car, and this problem does not exist at that end of the car. And even then, I have been known to drive up on at least 1x piece of 2x8 each side at the rear, simply to reduce the amount of jack pumping necessary to get the car up high enough for the jack stands. What really really shits me about Skylines is the lack of decent places for chassis stands at either end of the car. You'd think they'd be designed into the crossmembers.
    • I've got MCA Blues on my V36 Skyline, and while I've managed to sort out issues with scrubbing/bottoming out by raising it a smidge and increasing the damping hardness, the rear end still sounds *super* noisy when driving on anything other than the flattest surface imaginable. It sounds like a small party of flamingos are just chatting away in the back, which makes me think there are several link points in the suspension contributing to the noise. Am I hearing dried out/worn bushings? None of it sounds like metal-on-metal, it sounds more like hard rubber squeaking on metal. It's been suggested that a bit of silicon spray on each bushing might quiet them down, but I'm not sure what material the current bushings are made of (probably factory, I imagine) and whether silicon spray will degrade that material.
    • The obvious answer here is get a ND2/3 RF with the Targa top. The red is nicer, too!
