Are My Shock Fu**ked? (photos)
Have you flushed the initial fluid yet? It should look like a rainbow unicorn shat glitter into it. 2nd or 3rd fluid change is when you party. -
all brand new unit from Tomei, fluid, bearings, etc. Tomei said they call it a 1.5 lsd because its 100 percent lock up under acceleration and 50 percent under deacceleration. as I mentioned I used their fluid, install and their break-in procedure, (alot of figure 8's) but even when driving straight, or even slowly backing out of garage for first time, (at 2 mph) then driving to and from figure 8 parking lot, each tire in the rear would sporadically grab, skip, bounce, shutter and skip, shutter back a force I could feel causing clutch to slip then grab, at any speed. shaking entire car. I removed unit, since I put stock back in and all is fine, via process of elimination, its something with the lsd unit itself. I wasn't going to beat up the entire car more or change anything else for no reason as I had a feeling something in the lsd itself was wrong as everything was fine before this alone was installed and I rechecked over everything else after first time backing out I suspected an issue. I'll probably sadly already need new tires now just from trying to drive it 5 miles and performing the figure 8 break in. but if someone has any ideas I'm all ears
By funkymonkey · Posted
